Power Steering suddenly became hard to turn
Old Dec 23, 2018 | 02:28 PM
taiwoato's Avatar
Hi all,
I'm new here and I hope to get a solution to my problem. I have a 2007 RDX. drove this morning with a smooth running power steering. On getting to my destination I observed that it has become hard to turn. At a point it worked again, then stopped working, then work again and now not responding. Please help a soul
Old Dec 26, 2018 | 11:48 AM
Tomtwtwtw's Avatar
Any groaning coming from the power steering pump? If it's making noise, it should be easy to hear with windows down (maybe even with windows up). If so (and really either way), I'd recommend the following steps:
1. Check the power steering fluid level. The tank is just behind the passenger headlight, and has markings for high and low. (assuming left hand drive)
2a. If fluid is at correct level, then you likely aren't leaking (yet). Get it changed out asap. It's not hard to DIY, you can find a couple tutorials right on the site.
2b. If very low or no fluid in the tank, you may have a leak and should get it checked out by a shop.
Old Dec 27, 2018 | 04:53 AM
Midnight Mystery's Avatar
Null and proud of it
Power Steering issues are common on the RDX's, 2007 being the worst!
Mine whines sonetimes when parking after a long drive, usually in warmer weather, but it's really intermittent. Been like that since I got it in 2016, 63K miles later, no difference for me.
I like it heavy. But mine lightens up with rolling! Heavy-ish when parked, but not nearly as heavy as my TL was. You should check yours out, though!
Old Jan 3, 2019 | 11:00 PM
Poveiro's Avatar
I have a 2007 and have no problem or noise on power steering.
Check your oil, replace it if you can.
Check tension marks on tensioner, if not align up to specs, belt maybe to stretched, replace the belt.
Old Jan 5, 2019 | 06:00 PM
CSmoney28's Avatar
CSmoney28
Our trucks are know to have power steering rack leaks, see if yours is leaking it might have to be replaced.
Old Jan 5, 2019 | 07:03 PM
It's my power steering pump, have other priorities first, however.
Old Feb 23, 2019 | 09:14 PM
taiwoato's Avatar
Solved
Thank you all. I changed the pump and everything is fine.
Old Feb 23, 2019 | 09:32 PM
CSmoney28's Avatar
CSmoney28
No problem, I’m glad everything worked out for you. What did it end up costing for the parts and labor?
Old Jun 7, 2019 | 03:55 PM
taiwoato's Avatar
Sorry his took me a while. The cost was in Naira. As at then it will about $60
nitrousoxide10
Aug 10, 2016 02:21 PM
jwoods4290
Jul 24, 2016 10:35 PM
guyenacurazine
Apr 30, 2015 09:22 AM
RAC68
Apr 29, 2013 05:44 PM
bluerondo
Jan 15, 2012 06:09 PM
