Passing inspection problem
Old Dec 19, 2022 | 06:27 PM
rdkj2's Avatar
Hey guys so I’m having a problem were my RDX is tuned and doesn’t have cats but I need to get it inspected to be able to renew my Registration. Here in New York all these new laws passed on emissions it has gotten a lot tougher to do. My tuner also unfortunately passed away so now I’m trying to figure out what I can do, any suggestions?
Old Dec 19, 2022 | 11:51 PM
DaIll1's Avatar
If you have a compatible laptop you should be able to save your current tune and reload a factory tune with whatever software your tuner used. For the cats, you may be able to get them from a wrecker if you need factory or buy new https://acura.oempartsonline.com/search?search_str=Catalytic Converter&ptid=5808
Many states don't require factory cats after a certain amount of time and some don't require them at all prior an age of car. I live in Washington and is no longer tested. Check the requirements, you may be able to get away with a single high flow. By the way, their equipment can't test if tuned or not. Honda can, but not state testers, from what I've read.
Old Dec 20, 2022 | 09:36 AM
Tomtwtwtw's Avatar
Like you said, all states vary, but I think the most invasive states are still only checking for lack of emissions-related trouble codes (P0420 and the like), emissions readiness from vehicle self-test (catalyst, o2, evap, etc), and visual inspection to confirm car us unmodified (exhaust, intake, etc).
Be careful, as some tunes will disable readiness monitors to avoid throwing a DTC code, but that can still get detected by any standard OBD2 scanner. Hopefully that is not the case with RDX tuning - I know it was like this on a car I had some time ago and ended up having to flash it to stock and throw the cat back on to pass emissions.
Ludepower
3G RDX (2019+)
39
Sep 26, 2019 06:54 PM
Shank009
Jul 7, 2017 05:55 PM
Colorado Guy AF Ret.
Jun 4, 2012 08:05 AM
patek007
Apr 14, 2004 03:08 PM
