P0234 cel code
P0234 cel code
Hey guys, I got an issue with my RDX recently where I can't get past 3k rpm, as if theres a limiter. The check engine light came up and i got P0234, I did do some searching on it, i get it's an overboost issue, but can't really understand which part could it be. I read that some are saying it can be the waste gate, some saying it can be a leaky hose.
Anyone else had this issue in the past?
Car is bone stock no mods done to the car.
I would do a smoke test on it to verify if it is a vacuum hose leak . Once you do a smoke test that can help determine if it's bad hose or hoses if not next step would be checking the turbo wastegate for cracks or damage.
Its either a wadtegate issue bent rod on wastegate or crack other very possible issue is vacuum leak from a broken hose going to the boost controller. Start small and check the vacuum hose for cracks easily done with a smoke machine or blow smoke in the brake booster like and see where it comes out
CSmoney28
Just got this code sorry for the thread from the dead again. Cleared it but it didn't come back again yet...P0234 Turbocharger "A" Over-boost Condition. Going to try to change the Actuator Eye Bolt.
did the eye bolt change fix your prob?..i bought a while new actuator.. it should be here this week.
piggydog
02-11-2010 11:05 AM
