New from NC
Old Mar 18, 2020 | 12:55 PM
Cwhite87's Avatar
5th Gear
Thumbs up New from NC
Hello,
Im Clayton, i just joined in hope to get some in depth knowledge about my vehicles.
I Have a 03 CL typeS 6MT w 225k its my daily, My girl has 07 RDX, tech pack w 265k its her daily. We love both our vehicles, both are in stock form.
I have excessive oil consumption on the RDX its that pearl white color and the back is always sooted up. Also i have this sound resembles "holding a plastic bag in the wind" when you lift of the gas pedal.
Looking for another to track @virnow.com torn between are Crx, Crz kswaped, or Another RDX with mods for its 70/30 AWD capabilities
Old Mar 24, 2020 | 04:01 AM
carid's Avatar
Former Sponsor
Welcome to the forum, Clayton! Thanks for joining us. You've come to the right place - this forum really is a ton of help. With a little bit of research you can find an answer to all your questions.
Old Mar 26, 2020 | 04:17 PM
kevinh1919's Avatar
Hi, Clayton.
Welcome. There is a wealth of information throughout the site.
The following link is for the Charlotte area:
Charlotte
Old Mar 26, 2020 | 06:58 PM
Ron A's Avatar
Administrator
Welcome to the forums.
Since this is a topic/technical issue which will require replies and discussion, and not an introduction, this thread has been moved from the New Member Introductions forum to the model specific forum for better response.
Old Mar 27, 2020 | 10:17 AM
Tomtwtwtw's Avatar
If the sound is what I'm thinking of, for me it was a precursor to the P2263 code that many of us get at higher mileage, when the actuator bolt on the turbo wears into an oval shape. Started with the off-throttle noise, eventually the code popped. No real danger to keep driving the car, although low-rpm power/response will continue to dull and passing emissions may be an issue with an active code. Read through the long thread below, just in case this is around the corner for you.
https://acurazine.com/forums/1g-rdx-...oblems-861782/
Old Mar 28, 2020 | 11:43 AM
CLtotheTL32's Avatar
Welcome! Nice to see another NC member here. I would love to see pictures of your CL!
Old Mar 28, 2020 | 06:08 PM
Yumcha's Avatar
Welcome to the forums!
Old Sep 22, 2020 | 11:34 AM
Cwhite87's Avatar
5th Gear
Sorry for the delay, thanks for the hospitality since my last post i found a rdx with 100k miles in the junk yard scored the turbo off if for 65 dollars. the actuator bolt is in good shape. ordered the gaskets from acura and will be replacing soon.
but......
I have a new issue
Old Sep 22, 2020 | 09:28 PM
CSmoney28's Avatar
CSmoney28
Lightbulb
What's the new issue and also check the catalytic converter heat shields they can also be the culprit.
Tee2Green
Dec 21, 2019 02:31 PM
mdnichols
Oct 1, 2019 04:37 PM
Tammyw
Sep 17, 2019 09:08 PM
bellhead
May 19, 2018 12:47 PM
