Need help installing tps
Old Jun 22, 2007 | 12:02 PM
xh3atyx's Avatar
can anyone explain how to install my tps. just got rims and need the tps to be on my new rims thanks
Old Jun 23, 2007 | 12:19 AM
MikeRDXNJ's Avatar
You probably want to go to the dealer to get this done
Old Jun 25, 2007 | 12:36 PM
DNPhotography's Avatar
Photographer
you dont have to go back to the dealer to have this done. the place where you had your aftermarket rims installed can do this for you provided they know how to install a TPS correctly. just make sure they know what they are doing because to replace a TPS is quite costly. one question though, do you even have your TPS?
Old Jun 25, 2007 | 03:18 PM
sasair's Avatar
It's gonna be pretty costly because your tires are already mounted on your rims. The sensors themselves aren't too expensive to buy, like <$25 each. Not sure how much they will charge you to dismount the tires from the rims, install the sensors, remount the tires and rebalance. This all should have been done before you mounted the tires. Hopefully you have the equipment available to you to do it yourself.
Old Jun 26, 2007 | 01:19 AM
Photographer
i got a price of $73.11 each unit from Acura estore. where do you ge tit for 25 bucks? theres a set on ebay going for 40 bucks. BID!
Old Jun 26, 2007 | 07:17 AM
sasair's Avatar
Delray has them for $23 each.
Old Jun 26, 2007 | 09:28 PM
Photographer
wow~! i forgot that Acura estore goes through your local Acura dealer. that is a very big difference.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
