Keys stuck in ignition
Old Oct 29, 2010 | 08:15 PM
R_D_X's Avatar
Keys get stuck if i Reverse and put to Park. if i do a parallel park i have to from R to either N or D to P for the key to come out fine. is there something wrong with my tranny or some sensor maybe? it kinda worries me this might be a big problem in the future and its my first acura
Thank U
btw its an 08 non tech with 84000KM
Old Oct 31, 2010 | 06:57 PM
BigHatch's Avatar
not an SUV ...a Big Hatch
Is your steering wheel still turned all the way when you park? Maybe the steering lock is catching it.
Old Nov 8, 2010 | 08:35 PM
R_D_X's Avatar
thanks for reply sorry i completly forgot about this
so far its working fine now the steering wheel is not completly turned all the way i usually put the steering straight whenever i park. so im not really sure what couse it. im guessing maybe the gear lever wasnt fully set to park.
Old Apr 5, 2011 | 09:33 AM
PappyBear's Avatar
key stuck in ignition
My 2008 RDX did the exact same thing. I ended up having to remove the ground cable and left it overnight. the next morning it worked perfectly! No explanations except maybe the computer had to reset. Anybody else got any comments?
Old May 13, 2011 | 12:58 PM
Munkslyr's Avatar
I had the same issue and took it to Acura for warranty. My issue was the shifter cable was not tight and the car was not fully engaging in park...in turn I could not remove the key. All they did was tighten the cable and it was fixed.
Old May 13, 2011 | 07:54 PM
VQPower37's Avatar
this sound like it!
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
malvothegreat
Sep 29, 2015 12:38 AM
LoneRonin
Sep 28, 2015 09:11 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
