HVAC Problems
Old Jan 12, 2009 | 08:23 PM
albinati's Avatar
3rd Gear
HVAC Problems
Has anyone had problems with their HVAC?
Our RDX does not seem to be pushing any air with the fan on full. The fan is at top speed, but no air is coming out of any of the vents (doesn't seem to matter which setting is selected).
Old Jan 12, 2009 | 10:19 PM
IntegraVT's Avatar
Stealthy A-CL Member
No problems here.
But, do you hear the fan motor spinning at all? If not, check the blower fuse, it's #9 in the larger fuse box under the hood.
Old Feb 8, 2009 | 11:40 PM
rattmann316's Avatar
are you sure the vents are open?
Old Feb 20, 2009 | 12:18 PM
wd1541's Avatar
There was a re-call for my old 2005 MDX. I didn't think much of it and didn't get it fixed only affected vehicles below freezing temps. South Florida rarely happens. One day it was 29 degrees and the AC was stuck on Hi cold air and blowing on my feet. You should have it checked with the dealer.
My 2008 RDX has not had an issue. Also make sure the vents are open like rattmann316 suggested. There is a small wheel located next to the vent with a white dot. Try turning that.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
12vancover
Oct 16, 2015 12:04 PM
urbtsx
Sep 27, 2015 09:40 AM
