Driver door not unlocking
Old Jan 24, 2021 | 05:41 PM
Jibu's Avatar
4th Gear
Hi all, my 2011 RDX recently stopped allowing me to unlock any locks using the driver door lock button. It will, however, allow me to lock the doors, including the driver door. The passenger side door button will lock and unlock all doors. Also, the remote will lock and unlock all doors including the driver door.
Any ideas on what the issue is or how I can diagnose it? Thanks in advance.
Old Jan 24, 2021 | 07:57 PM
DaIll1's Avatar
Sounds like the switch is either bad or came unplugged.
Old Jan 24, 2021 | 08:15 PM
Jibu's Avatar
4th Gear
Thanks - If that’s the case, would it make sense that it does lock but just does not unlock? If so, what do you think would resolve it? Yesterday, the unlock did randomly work again, but then stopped again on the next ride.
Old Jan 24, 2021 | 10:12 PM
DaIll1's Avatar
Sometimes the contacts corrode from moisture. You can try holding the switch in the unlock position and wiggle it side to side to rub the contacts together. Don't reef on it or you will have to replace it haha.
Old Jan 25, 2021 | 08:41 AM
Jibu's Avatar
4th Gear
I tried as suggested but it did not seem to do anything. Anything else?
Old Jan 25, 2021 | 11:13 AM
DaIll1's Avatar
My '16 ILX had a TSB for the driver door switch panel, so it is an ongoing issue. I've removed the door panel, but didn't look to see how easy it would be to disassemble the switches to clean. You may have to replace it.
Old Jan 25, 2021 | 12:56 PM
Jibu's Avatar
4th Gear
Thanks - do you know if it was the same exact scenario that I described in the original post? Do you know what the dealer needed to do to resolve the ILX issue?
Old Jan 25, 2021 | 02:48 PM
DaIll1's Avatar
The ILX issue caused some fires and I don't know what they did to fix the problem.
Old Jan 26, 2021 | 12:37 PM
CSmoney28's Avatar
CSmoney28
Try this it may help you out
HuKaShI
Jan 13, 2016 01:30 PM
Thatguysstuff
Feb 6, 2013 06:01 PM
guitarplayer16
Mar 7, 2012 11:03 PM
FR4NCH1SE
Apr 7, 2009 01:30 AM
