Door Locks.
Door Locks.
As all RDX, use key fob to unlock car. Get in car, start up and begin driving. doors will lock.
Mine when you stop anytime, and begin to drive again the doors locks will lock. They dont unlock when stopped, but when u begin to drive again they activate again. They unlock when car is placed in park.
When exit car, lock doors with key fob. Doors lock, lights wont flash nor will the car "beep" when you press twice.
Anyone with similar issues or have had the problem resolved?
I did have a bad actuator replaced 2 months ago.
mrgold35
Check out this link for all the M.I.D. setup. Steps 6, 7 & 8 control the door lock/unlock conditions (shift from P, with vehicle speed, etc...). I have mine set to unlock all doors with fob, lock all doors when shift from "P", and unlock all door when shift into "P". The pdf link is from a 2009 RDX, it should work for the 07-12 model:
http://dealer.webmakerx.net/Images/S...t/09%20RDX.pdf
2nd
should be pretty straight forward, use the buttons on the bottom right of your steering wheel to control the little screen in between the MPH & RPM gauges.
Its all good. you guys never read what I wrote properly. Its got nothing to do with the MID setup. Thats only for when you put the car in park or start the car. It has NOTHING to do with driving the car. Driving is when the problems occur.
How about you take the advice you were given, and reprogram your settings.
What's the worst that could happen? It doesn't fix your problem? Seriously, change your settings. Nothing is wrong.
So when Im in stop and go traffic, like I am daily, resetting is going to solve my problem? It never use to lock 300 plus times a day in traffic.
mrgold35
from the weblink above:
STEP 7
Auto Door Lock Select when the doors automatically lock.
SHIFT FROM "P" The doors will lock when shift lever is moved out of Park (P)
WITH VEHICLE SPEED THE DOORS WILL LOCK WHEN VEHICLE SPEED REACHES 10 mph (approximately) Sounds like your setting
OFF Auto door lock function is deactivated all of the time
STEP 8
Auto Door Unlock Select when the doors automatically unlock.
SHIFT TO "P" DRIVER DOOR DRIVER DOOR UNLOCKS WHEN SHIFT LEVER IS MOVED INTO PARK (P)
SHIFT TO "P" ALL DOORS All doors unlock when shift lever is moved into PARK (P) Sounds like your setting
IGN OFF DRIVER DOOR Driver door unlocks when ignition switch is turned off
IGN OFF ALL DOORS All doors unlock when ignition switch is turned off
OFF/DEACTIVATED Auto door unlock function is deactivated
STEP 9
Keyless Lock Acknowledgement ___ON ___OFF
The exterior lights flash each time you press the LOCK or UNLOCK button. A beep will also sound when you press the LOCK button twice.
Your setting may be set to OFF
Pull the negative terminal.
Tried everything you guys mentioned and no change.
-unlock doors with fob, all markers flash (normal)
-lock doors with fob, No markers flash, and No beep.
-start car, put into drive, accelerate, doors lock (normal)
-stop at stop sign, continue to drive, doors actuate
-stop in traffic, accelerate, doors actuate
-slow to a crawl, and speed up again, doors actuate.
Went through MID, all is way it should be, disconnected Negative terminal for 10 min, reconnected, NO change
Im at a total loss and frustration with this car. I have had SOOOO many issues with it. At least my local dealership looks after me very well, although its been 3 years since I bought it and probably once a month something needs repaired..lol.
3rd Gear
Can these setting be customized on the base RDX? On the upper top right of the pdf it sounds like it can be done on a base, but it does not have the MID. Thats the only instructions it gives is doing it via MID.
exactly... I have an 07 Base... no INFO button to activate these settings... anyone know the way to do this on the "original RDX"
Well the issue lasted almost a month and then resolved itself. Two days ago it started to happen all over again. Took it to the dealer instantly and lucky for me they had a courtesy car so they could research my issue. Low and behold, the rear passenger door and the hatch lock are on the same relay. The relay failed and was causing the issue. The car actually had a code. I was shocked by that and mentioned that I used a code reader on it and found nothing. They just laughed and said there reader will find everything. i left it at that, and car was repaired.
soupi
14
11-15-2015 11:15 AM
