check engine and SH awd vsa abs light
Hey guys
I have 07 RDX tech with CP-E intake I was driving tonight out of no where all the light came on i got a P0102 MAF low input and SH-awd and vas light. so i stop and restart the car the sw awd and the vas light went off just the check engine light still on
I have few ideas about what to do but i would like more ideas
I would
1. change the air filter
2. clean the MAF
3.check the connection on the maf
thanks
I would
2. clean the MAF
thanks
How did you reset your ECU? Don't wanna hijack your thread...I've just been trying to reset mine and I can't. I've disconnected the negative battery terminal for ~10 minutes. That didn't work. I've disconnected the negative battery terminal AND disconnected the connectors on the ECU for ~10 minutes...still didn't work. My radio presets are preserved, my auto-door-lock prefs are preserved
How did you reset your ECU? Don't wanna hijack your thread...I've just been trying to reset mine and I can't. I've disconnected the negative battery terminal for ~10 minutes. That didn't work. I've disconnected the negative battery terminal AND disconnected the connectors on the ECU for ~10 minutes...still didn't work. My radio presets are preserved, my auto-door-lock prefs are preserved ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
Leave it alone or 5 to 10 minutes.
See if that would work or you. (Radio preset has nothing to do with resetting the ECU with the cel/codes that comes up)
^^ That same thing happened to me a couple of months after I got my RDX. I saw a few lights come up on the dash and freaked out. Turned my car off and on and everything seemed to be ok. It happened after I hit a pretty good bump. Apparently my positive battery cable was loose.
mada51589
05-03-2022 08:54 PM
