Burning Lots of Oil
Old Mar 11, 2020 | 10:32 PM
ljcolomacks's Avatar
Burning Lots of Oil
2009 Acura RDX 1G
Hello everyone, looking for input on my current situation. The last couple of oil changes I have lost a good 2+ qt's of oil between changes.
I wasn't even able to make it the full cycle because it was losing so much. Clearly there are no leaks so it has to be internal.
Other than oil loss the only symptoms are a little oil in the intercooler and smoke when flooring the car. There is no smoke during normal driving conditions.
It does have a tune on it with bigger injectors so I originally thought the smoke was from the air-fuel ratio.
Any input on this would be much appreciated. Has anyone else experienced this with the RDX?
Thanks, Macker
Old Mar 12, 2020 | 07:19 AM
Altair's Avatar
Originally Posted by ljcolomacks
2009 Acura RDX 1G
...there are no leaks so it has to be internal... a little oil in the intercooler and smoke when flooring the car. There is no smoke during normal driving conditions.
Any input on this would be much appreciated. ..
Thanks, Macker
Hi!
Start by check/replace PCV first.
https://acurazine.com/forums/1g-rdx-...61/pcv-701096/
then read this:
https://acurazine.com/forums/first-g...h-cans-682236/
let us know how it goes
Old Mar 15, 2020 | 11:18 PM
Originally Posted by Altair
Hi!
then read this:
Altair,
Thanks for taking the time to respond. It seems like an inexpensive solution so will be worth a shot.
I will let you know if I have any luck with this. I called the dealer and they stated that losing a qt of oil per 1000miles was in spec.
That spec seems pretty outrages to me lol. I'd have to add 3qt of oil between every oil change at that rate. Crazyness.
Thanks, Luke McCormack
mkwon3
2G RDX DIY & FAQ
Nov 22, 2017 01:01 PM
pickler
1G RDX (2007-2012)
25
Jun 20, 2011 12:56 AM
dcmodels
1G RDX Problems & Fixes
Feb 5, 2010 12:56 PM
Rexorg
1G RDX (2007-2012)
Sep 17, 2008 09:22 AM
stappy
1G RDX (2007-2012)
14
Mar 15, 2008 07:56 PM
