Air mix motor?
Old 09-09-2017, 09:55 PM
dinot's Avatar
Air mix motor?
Hey folks,
I have an A/C problem on an 2007 RDX Tech and it really seems like the problem is the air mix door on the passenger side. I have no idea where this motor resides. I have been looking for it on parts diagrams but since I don't know where it is, I have been unsuccessful.
Can someone point me to a diagram or part number? I'd like to order this part and swap it out.
Thanks,
Old 09-19-2017, 12:03 PM
mrgold35
mrgold35's Avatar
Received 1,508 Likes on 1,176 Posts
I saved a copy of the 2007 Acura RDX service manual on my Dropbox (around 140 MB). Hopefully, this should give you step-by-step instructions on the air mix motor: https://www.dropbox.com/s/y3oyrs1nds...ANUAL.pdf?dl=0
Old 09-20-2017, 06:58 AM
dinot's Avatar
Thank you!!!
Old 10-09-2017, 01:51 PM
John Curtis's Avatar
Yes, Thank you! I've been diagnosing a no heat problem and believe I have narrowed it down to the driver side air mix motor. It doesn't move at all regardless of temp.
Old 01-08-2019, 07:12 PM
jttjk's Avatar
Dropbox file still available?
Originally Posted by dinot
Thank you!!!
is that Dropbox file still available for me to use? I have a heat problem too. Need to see the air mix diagram.
Thank you.
Old 01-12-2019, 06:40 PM
CSmoney28
CSmoney28's Avatar
My drivers side is going, this truck is great but the parts always seem to break.
Old 02-18-2019, 04:00 PM
Poveiro's Avatar
I had a similar problem wile back, was the cable that moved away, replaced and tighten the clip and all is good.
Old 02-18-2019, 07:22 PM
CSmoney28
CSmoney28's Avatar
Do you mind explaining to me how you fixed it in more detail so I may try to attempt it myself...thank you.
Old 02-18-2019, 08:03 PM
Poveiro's Avatar
@CSmoney28
This was long ago, memory is that I removed the cable from the clip, grease the track some how made the clip had more pressure, You can put some glue.
you have to be sure that is either full open or full close so you no its the right position.
My problem was the door would go all the way so did had the requested temp.
Car is on stands, easy to take picture, but battery is removed, cant make it move so I can recall better them this, sorry
You can see the door motor also.
This is the drivers side, the passenger side is covered.
Old 02-18-2019, 08:10 PM
Poveiro's Avatar
Hey folks,
Thanks,
@dinot
You may be looking for 12or 14 not certain.
I'm not sure if I can post this here, hope not to get in trouble.
https://www.acurapartswarehouse.com/...ater-unit.html
Old 02-18-2019, 10:55 PM
CSmoney28
CSmoney28's Avatar
Thank you, mine is in it’s way out and I don’t feel like purchasing a new one if I can just fix it myself. It annoys my passengers more than me haha.
Old 11-03-2019, 06:58 AM
Jpiazza's Avatar
Dropbox link still active ?
I just bought a 2007 RDX - this would be very handy. Thank you !
Old 11-03-2019, 07:42 AM
mrgold35
mrgold35's Avatar
https://www.dropbox.com/s/raytzw85fw...ANUAL.pdf?dl=0
Here is a link to view and you should download the pdf also. Let me know if it doesn't work.
feralcomprehension (11-03-2019)
Old 11-03-2019, 07:56 AM
Qualified Observer
feralcomprehension's Avatar
Thank you Mr.G
Old 11-03-2019, 07:58 AM
Jpiazza's Avatar
Worked - thanks !
It works- thanks !
mrgold35 (11-03-2019)
Old 08-18-2021, 10:36 AM
CSmoney28
CSmoney28's Avatar
Unhappy
Need help finding this part sold out everywhere because it's discontinued. I have code B1234 ACURA - Short In The Driver Side Air Mix Control Motor Circuit
