Air mix motor?
Old Sep 9, 2017 | 09:55 PM
dinot's Avatar
Air mix motor?
Hey folks,
I have an A/C problem on an 2007 RDX Tech and it really seems like the problem is the air mix door on the passenger side. I have no idea where this motor resides. I have been looking for it on parts diagrams but since I don't know where it is, I have been unsuccessful.
Can someone point me to a diagram or part number? I'd like to order this part and swap it out.
Thanks,
Old Sep 19, 2017 | 12:03 PM
mrgold35's Avatar
mrgold35
I saved a copy of the 2007 Acura RDX service manual on my Dropbox (around 140 MB). Hopefully, this should give you step-by-step instructions on the air mix motor: https://www.dropbox.com/s/y3oyrs1nds...ANUAL.pdf?dl=0
Old Sep 20, 2017 | 06:58 AM
dinot's Avatar
Thank you!!!
Old Oct 9, 2017 | 01:51 PM
John Curtis's Avatar
Yes, Thank you! I've been diagnosing a no heat problem and believe I have narrowed it down to the driver side air mix motor. It doesn't move at all regardless of temp.
Old Jan 8, 2019 | 07:12 PM
jttjk's Avatar
Dropbox file still available?
Originally Posted by dinot
Thank you!!!
is that Dropbox file still available for me to use? I have a heat problem too. Need to see the air mix diagram.
Thank you.
Old Jan 12, 2019 | 06:40 PM
CSmoney28's Avatar
CSmoney28
My drivers side is going, this truck is great but the parts always seem to break.
Old Feb 18, 2019 | 04:00 PM
Poveiro's Avatar
I had a similar problem wile back, was the cable that moved away, replaced and tighten the clip and all is good.
Old Feb 18, 2019 | 07:22 PM
CSmoney28's Avatar
CSmoney28
Do you mind explaining to me how you fixed it in more detail so I may try to attempt it myself...thank you.
Old Feb 18, 2019 | 08:03 PM
Poveiro's Avatar
@CSmoney28
This was long ago, memory is that I removed the cable from the clip, grease the track some how made the clip had more pressure, You can put some glue.
you have to be sure that is either full open or full close so you no its the right position.
My problem was the door would go all the way so did had the requested temp.
Car is on stands, easy to take picture, but battery is removed, cant make it move so I can recall better them this, sorry
You can see the door motor also.
This is the drivers side, the passenger side is covered.
Old Feb 18, 2019 | 08:10 PM
Poveiro's Avatar
Hey folks,
Thanks,
@dinot
You may be looking for 12or 14 not certain.
I'm not sure if I can post this here, hope not to get in trouble.
https://www.acurapartswarehouse.com/...ater-unit.html
Old Feb 18, 2019 | 10:55 PM
CSmoney28's Avatar
CSmoney28
Thank you, mine is in it’s way out and I don’t feel like purchasing a new one if I can just fix it myself. It annoys my passengers more than me haha.
Old Nov 3, 2019 | 06:58 AM
Jpiazza's Avatar
Dropbox link still active ?
I just bought a 2007 RDX - this would be very handy. Thank you !
Old Nov 3, 2019 | 07:42 AM
mrgold35's Avatar
mrgold35
https://www.dropbox.com/s/raytzw85fw...ANUAL.pdf?dl=0
Here is a link to view and you should download the pdf also. Let me know if it doesn't work.
Old Nov 3, 2019 | 07:56 AM
feralcomprehension's Avatar
Qualified Observer
Thank you Mr.G
Old Nov 3, 2019 | 07:58 AM
Jpiazza's Avatar
Worked - thanks !
It works- thanks !
Old Aug 18, 2021 | 10:36 AM
CSmoney28's Avatar
CSmoney28
Unhappy
Need help finding this part sold out everywhere because it's discontinued. I have code B1234 ACURA - Short In The Driver Side Air Mix Control Motor Circuit
Old Jan 17, 2025 | 02:12 PM
Leadfooter's Avatar
Still a thing
I suspect this issue will continue for those rocking this fun ride.
Mine: '07 RDXtech
Cold air only on Driver's side
Found blend door cable to be disconnected from actuator arm completely. Also actuator motor was locked.
These items are visible from driver's foot well as pictured by others. Removal is 3 - 7mm coarse hex head screws. Plug connector has a release tab. Remove the 2 - 12mm nuts mounting the accelerator for ease of access.
If you can unbind the actuator great but if like mine it will need replaced. Determined a small gear mounting shaft had broken from the case inside, causing a bind that could not be reasonably repaired. The case locking tabs were very brittle and broke easily. I'd assume that is exactly what happened inside and if measured would prove to be a common fail point. Too bad though, all the gears were in great shape and would have continued to function if only they had used a metal or more substantial plastic shaft for the gears to run on.
$45 tomorrow part on Amazon. Others $25 -$115
