Is the AC covered under warranty?
Old Jul 28, 2010 | 03:21 PM
huemoua's Avatar
Hi guys,
My 08 RDX AC doesn't blow cold air like it use to be, nor does it blow warm air. It's just blow cool air so my question is does the AC cover under the warranty? My RDX only got 35k mileage on.
Does any know the answer or had this problem with their RDX?
Thanks guys.
Old Jul 28, 2010 | 03:36 PM
SinCity's Avatar
If it is low on freon, probably not. If there is a leak somewhere in the system, it should be. It just sounds like you are low on freon since you said it is "cool."
Old Jul 28, 2010 | 03:49 PM
R*D*X*'s Avatar
freon is not a consumable part of your airconditioner so if you're low on freon you have a leak on your AC system...
Old Jul 28, 2010 | 03:50 PM
R*D*X*'s Avatar
Originally Posted by huemoua
Hi guys,
Thanks guys.
You can always get a free quote from your delaer and they should tell you if its covered by your warranty
Old Jul 28, 2010 | 09:37 PM
huemoua's Avatar
The thing is that the nearest Acura dealer is 45-50 miles from here. I might have to call and schedule an appointment to have them check it out. Hope for the best... Thanks.
Old Jul 28, 2010 | 10:30 PM
ozwaldo's Avatar
Hmmm, mine has been working good on most days, but every few weeks it will not cool well. Plus at times I'm getting "smoke" from the vents. Not all the time, but every few weeks at random. Is anyone else seeing this? I fear taking it to the dealer and they find that everything is okay on that day.
Old Jul 29, 2010 | 07:25 AM
Nyjumpman23's Avatar
ACURA ENTHUSIAST
If your getting smoke from the vents it could be the basis of humidity via climate change and instance turn on/off AC.
If it's constant, I'd check w/ the Service area then.
Old Jul 30, 2010 | 01:10 PM
Mrgoody's Avatar
Hi guys,
Thanks guys.
Yes it is covered under standard warranty, Take it to a dealer.
Old Jul 30, 2010 | 01:31 PM
R*D*X*'s Avatar
If its blowing white smoke from your vent you might need to check your AC receiver-dryer
Old Jul 30, 2010 | 02:23 PM
drew11588's Avatar
dealers charge for inspection if they find the problem is not covered under warranty and you do not get the problem fixed from them. When my a/c stopped blowing cold air, they determined a rock flew in the front grill and punched a hole in the condenser. not covered under warranty since its physical damage. dealer wanted over a grand. got it fixed locally for 600... hopefully thats not what happened to you tho
Old Aug 2, 2010 | 06:25 PM
huemoua's Avatar
Thanks MrGoody. I will make an appointment and go there. I'll let you guys know the result afterward.
Old Aug 25, 2010 | 03:17 PM
Mrgoody's Avatar
So how did the appointment with dealer go?
Old Sep 25, 2010 | 11:54 AM
huemoua's Avatar
hey guys I took my rdx to the dealer today (Sept 25th) and yeah they fix it, cold as ice again. The dealer fix it under warranty, they told me it's the compressor.
Old Sep 25, 2010 | 05:11 PM
ozwaldo's Avatar
Good to know - my appointment is Friday. I'm getting the "smoke" about once a week now, and the AC seems slower to cool.
Old Sep 27, 2010 | 03:01 PM
answeris2's Avatar
Yeah, you may want the dealer to check that out because I had a leak in my A/C compressor. They ended up replacing the whole damn unit. My indication wasn't smoke though...it was clearly dust. Dust that you were able to see and taste...freaking nasty. Here was my post of the whole ordeal.
https://acurazine.com/forums/1g-rdx-problems-fixes-160/cabin-air-conditioner-blows-lots-dust-717032/
Old Oct 11, 2010 | 01:40 AM
huemoua's Avatar
https://acurazine.com/forums/showthread.php?t=717032
Not worrying about it anymore since I trade in for a 2011 Hyundai Sonata (limited) and love it. I miss the turbo power of the RDX, but what for I'm getting for it's worth it.
Old Nov 16, 2010 | 09:16 AM
DGL's Avatar
DGL
3rd Gear
Most likely not. My experience with my 2007 RDX Acura is that nothing is covered under warranty - they always find a way out - usually they say sit was caused by "routine wear and tear" or lack of regular maintenance. Good luck. I've tried two different dealers and this is consistent.
Old Nov 16, 2010 | 02:17 PM
XIS's Avatar
XIS
Lizard King
most likely IS....
If you have a malfunction or a failure and IF you are still under warranty, it should be covered under wty.
Old Nov 16, 2010 | 02:25 PM
Mr Marco's Avatar
Yep, lots of stalling from the dealer on clear issues of Acura covered items. It will be interesting to see if they work with me on the extended warranty we bought. Have them on both cars and even thought kept telling my wife they were a waste of money. Piece of mind, ??? A gamble that,
  • That a product will break exactly after the manufacturer's warranty has expired and precisely when the extended warranty is in effect. Sure, it's possible, but unlikely.
  • That the cost of the repair will exceed the cost of the warranty. Surveys of Consumer Reports subscribers reveal that the costs are fairly close most of the time.
  • That the product is likely to break in the first place. According to our data, most products are quite reliable and have not broken during the first three or four years of ownership.
  • That you're going to want to have the product fixed. Perhaps surprisingly, many readers surveyed said they didn't bother seeking repairs because they desired a replacement product that had either new features, more power, greater flexibility, more advanced technology, or improved energy efficiency.
InFaMouSLink
Oct 27, 2015 06:52 PM
BIGxRED
Oct 19, 2015 10:47 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
