142k maintenance
Old Sep 26, 2015 | 02:10 PM
jubikej's Avatar
6th Gear
142k maintenance
Hi everyone,
I have a 2007 RDX with 142k miles. Oil life indicator now is at 40%. I want to change oil right now due to his age (over 1 year). What maintenace should I do? A,B,1,2,3,4,5,6?
thanks for help
Old Sep 27, 2015 | 12:31 PM
Tomtwtwtw's Avatar
No clue, but if you're not sure just change the oil now and don't reset the maintenance minder - in another couple thousand miles or so it'll tell you what else to do. If you have no records of prior maintenance at all, inspect and/or replace all the usual suspects - brakes, spark plugs, all fluids, serpent belt, etc.
Old Sep 30, 2015 | 01:08 PM
schen72's Avatar
I think I read in the manual that if you reset the maintenance minder before the 15% message appears, it will also display what service(s) it would have called for. But double check the manual so you don't mess up the interval. I routinely go more than 1 year between oil changes because I don't put that many miles on my RDX. I personally would just wait until it got to 15%.
Old Sep 30, 2015 | 01:10 PM
^the manual states to change when at 15% or lower or one year.
your bad advice contradicts your good advice!
Old Sep 30, 2015 | 01:13 PM
if I had the 2007 RDX, I would do regular maitenance.
at 142k miles, I would change out all the fluids....coolant, oil, brake fluid, power steering fluid (if applicable).
then I would check brake pads and rotors. inspecting them to see how much life they have left, or if they are done, install new ones....
check/inspect tires for any ununiformed/irregular wear.
check/inspect motor mounts, all mounts in general, including suspension bushings.
acuratl26
Apr 23, 2020 07:30 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
polish_pat
Sep 30, 2015 12:22 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
