resonator
resonator
Has anyone tried just removing the resonator? Im wondering if it would make any difference in the sound of the exhaust. My guess would be no, but I would like to had a tiny bit more sound on hard acceleration.
I deleted my resonator a few months ago and it does help out with the exhaust note a little bit. Cabin noise is up (it's not a bad sound), the sound is a bit more throaty in it's character and does make some really nice sounds when you are behind the car. Performance wise, it has helped the turbo spool up a little bit sooner, in the slightest of ways. The fuel economy I have observed after doing the delete has also improved even with me being a little heavier on the throttle (there is a sweet spot where the exhaust just sounds fantastic). All in all, I found it to be an easy and inexpensive mod that has helped get spice things up with the car since i have problems with getting bored with cars very easily. I say if you are considering doing it, just go ahead and do it.
I have done it and don't recommend doing it. It's there to eliminate engine drone, especially at low, cruising RPMs. I started to get annoyed from the drone on trips with friends. It made the music harder to hear.
There is a slight increase in throatiness at WOT without it. I didn't notice that the turbo spooled up quicker compared to getting a downpipe, which was very noticable.
If you're going to do it all you need is a 2.25" straight pipe (aluminized steel is cheap). Simple cut and weld job. Reduces weight too.
So I went out and got a piece of 2.25" pipe flared on both sides. I was about to cut out my resonator when I noticed that the incoming pipe looks like 2.25" but the outlet looks more like 2". Im I right, or are my eyes playing tricks on me?
I love the low deep tone of my 3"inch with cat delete. For me, I only get that deep low tone when under boost in high gears. It sounds like stock or close to it under normal driving, for me at least.
ExcelerateRep
Dec 11, 2015 12:58 PM
