Rear toe links !!!!
Old Oct 13, 2014 | 11:49 AM
TheWrench116's Avatar
FLETCH
Rear toe links !!!!
can someone confirm the length of the rear toe links for me I measured mine but am not listing it intentionally. I am actively trying to find a suitable replacement that doesn't involve me making them in my basement. just order and bolt on.
Old Oct 15, 2014 | 03:50 PM
FLETCH
buler
bueller
bueller
bueller........................................... ..........
Old Oct 15, 2014 | 04:25 PM
bluecarbonfiber's Avatar
WTF?
i posted one of the toe links in comparison i think the main adjustment is pretty much the whole lower portion of the suspension in the rear
we truly need a camber arm the toe has plent of room for adj
Old Oct 16, 2014 | 09:02 AM
FLETCH
the factory toe link isn't adjustable. only the camber as far as I'm aware anyway. ill look into getting the camber to be more adjustable.
Old Oct 16, 2014 | 10:23 AM
WTF?
when i was at heeltoes a few weekends ago we found out the toe bolts are the ones you see under the vehicle with the notches in the washers
its why both sides of the bolt have washers with notches
Old Oct 16, 2014 | 10:29 AM
FLETCH
so your telling me that the eccentric bolt that is adjustable isn't for the camber...?... and that the toe is adjustable someplace other then the toe link??? cause that seems like stupid engineering to me.
Old Oct 16, 2014 | 11:09 AM
WTF?
yup.. that bar i posted above is more of a stable bar.. it will adjust the toe a smidge if you were to find an adjustable one but if you look at how its installed its not really ment to be removed i was trying to upload a photo but the whole acurazine picture folders have changed and i think we have to wait for them to be approved now or something
honda and acuras never really have issues adjusting toe its always been the camber that has caused issues.. the only thing i can think of for our camber issue is an adjustable ball joint or a new upper piece made from scratch that is adjustable .. it will need to have a curve in it though cause ours does for when the vehicle squats and needs to clear the inner fender
Old Nov 11, 2014 | 05:43 PM
RDHORSE's Avatar
Target RDX-TB1 Mkt...
Able to achieve 4-wheel toe alignment w/Eibach springs. Required replacement of "toe adjustment bolts" and a competent chassis team. IT CAN BE DONE . Rear camber is within specs, yet negative enough for performance )))).
Old Nov 19, 2014 | 10:14 PM
BigHatch's Avatar
not an SUV ...a Big Hatch
does this mean you've done it? Please share if so.
BoricuaTL
Apr 8, 2016 01:08 PM
Sep 14, 2015 10:09 PM
ivegotthenav
Sep 11, 2015 07:51 PM
RK_AcuraTL
Sep 5, 2015 02:26 AM
