K23a1 Build
Old 02-24-2016, 07:43 PM
  #1241
KenB350z's Avatar
Piston are in, now waiting on the rods. When they come I will be shipping out the block.
Old 02-24-2016, 07:49 PM
  #1242
KenB350z's Avatar
Originally Posted by TheWrench116
what about the compound setup? thats going to need like 2xxx or maybe just 4 1/4 fuel lines run to the intake and open ends?.? LOL
What you talking about dude? Here are the twin charged Lotus mods. They only used 750cc's, I think I'm gold. And that thing was a beast!
ENGINE
Engine Code: 2ZZ-GE
Displacement (cc): 1,798cc
Bore & Stroke (mm): 82mm x 85mm
Peak Horsepower (@ RPM): 413.2 hp @ 7,500 RPM (17psi)
Peak Torque (@ RPM): 413.2 hp @ 7,500 RPM (17psi)
Dyno Type: Dynapack
Engine Builder: Stafford Fabrication (SF)
Block Modifications: Darton Sleeves
Pistons/Compression Ratio: Wiseco 9.0:1 Compression Pistons
Connecting Rods / Crank: Crower Forged-Steel Connecting Rods
Valves / Springs / Retainers: Monkey Wrench Racing Valves & Retainers
Eibach Valve Springs
Head/Main Studs: ARP Head Studs
Intake Manifold / Throttle Body: Ronin/SF
Air Induction System: Ronin/SF
Fuel Injectors: Siemens 750 cc/min Injectors (x4)
Fuel Delivery System: Walbro 255-lph In-tank Fuel Pump
Ronin/SF Swirl Pot and Fuel Return
Aeromotive regulator
Engine Management System: CharlieX Reflash
Engine Management Tuner: CharlieX/Ronin
Boost Controller: AEM Electronic Boost Controller
ARK Design Electronic Boost Controller
Ignition System: Okada Projects Coils
Spark Plugs: Denso IK24
Exhaust Manifold: SF
Exhaust System / Downpipe:: Custom 3-to-4-inch Stainless-steel Exhaust
Wastegate: TiAL Sport 44mm Wastegate
Blow-Off Valve: Turbonetics Raptor
Intercooler: Ronin/SF Spearco Chargecooler
Cooling System: Dual Pro Alloy Radiators
Oil System: CircuitWorx Oil Pump w/ Oil Cooler
Old 02-24-2016, 08:21 PM
  #1243
KenB350z's Avatar
Also looking to get the piston's anodized, heard that's a good thing.
Old 02-25-2016, 03:56 AM
  #1244
Slow98teg's Avatar
Ken I had mine done by FFWD Connection out close to you in OK.
http://www.ffwdconnection.com/index.php/coatings/pistoncoating.html
Old 02-25-2016, 04:23 AM
  #1245
Slow98teg's Avatar
Inola, OK however far from you that is.
And that lotus is not on ethanol. He doesn't need that big of a fuel system.
Old 02-25-2016, 06:46 AM
  #1246
KenB350z's Avatar
Inola
He was/is running a dual fuel system, one with gas the other with isopropyl alcohol.
Old 02-25-2016, 06:30 PM
  #1247
KenB350z's Avatar
I was told to line up the timing chain cover to make sure it lines up perfectly with the k20 head. Well it lines up pretty good so I might be putting the K20a head on my current setup within a couple of weeks depending on what's going on with my mechanic.
Old 02-25-2016, 06:58 PM
  #1248
KenB350z's Avatar
FFWD - Piston Coating
I'll check them out, thanks.
Old 02-26-2016, 02:47 PM
  #1249
KenB350z's Avatar
Forgot about the weight difference. Not sure what the piston coating will add. I will weight it again after it gets done.
Old 02-26-2016, 05:11 PM
  #1250
KenB350z's Avatar
Nuke Performance fuel surge kit, finally came. The packaging looks like it came out of an Apple store; pretty impressed!
Old 02-26-2016, 10:16 PM
  #1251
Haré romel's Avatar
Yeah, fit perfectly , is k23 timing chain cover?
I m excite with this project, I think I'll do this wonderful frankie but with my original exhaust manifold and block water port spacer. I'll feed the manifold with coolant by outside. My rdx feel fast right now, so I believe turbo upgrade support that frankie. I'm 7500 rpm limit maybe can up to 8000 rpm with frankie (I like high rpm), but I don t know if OEM oil pump support. My old crv k20/k24 with oem k24 oil pump cavity at 8,000.00, i think k23 oem oil pump do same thing because have the same internal trans.
What do you do with oil pump? stay OEM or k20a2 fit or erl s2000 fit?
__________________________________________________ ____________
2009 RDX, flashpro, BC cam, RV6, ZDX tb, skunk2 intake manifold, water intercooler, turbo upgrade.
Old 02-28-2016, 07:26 AM
  #1252
KenB350z's Avatar
The OEM twin gear pump robs the engine of some existing power, so would definitely upgrade to the K20a or F20c pump. If you don't mind some vibration noise's, because I believe it acts as a engine damper down below. That's just what I've researched anyway.
Old 02-28-2016, 07:39 AM
  #1253
KenB350z's Avatar
Here is the Nuke Performance surge tank half assemble.
Old 03-01-2016, 06:07 PM
  #1254
KenB350z's Avatar
I wonder if I can beat one of these now?
Old 03-01-2016, 08:36 PM
  #1255
Slow98teg's Avatar
I beat one at the track when I was only intake and e85 tune.
Old 03-01-2016, 11:16 PM
  #1256
KenB350z's Avatar
Good, should be a piece of cake then..
Old 03-01-2016, 11:26 PM
  #1257
KenB350z's Avatar
Sexy twins!
Old 03-02-2016, 01:28 PM
  #1258
RDX10's Avatar
Any idea what year it was? The 2006-2010 ones were 4.7 0-60, the 2012-2013 ones were horribly slower with only 5.3 0-60. And the newest 2014+ do the deed in 4.3. So year really depends.
Old 03-02-2016, 06:48 PM
  #1259
Slow98teg's Avatar
Not a 1st gen. Everyone has different 0-60 times. This one went 14.0@99-100
Old 03-02-2016, 10:23 PM
  #1260
Haré romel's Avatar
K23a1 Block
Crank is back in the block, just waiting on the other parts to get here. After parts arrive, I will be shipping it out to ERL/Drag Cartel. I guess Drag is the distributor now; however, ERL still does the block work. At least that's what I was told by Drag.
I look up how to ship a block in the link below, I've never ship one before.
- Darton Sleeves
I see that k20a2 oil pump don t fit rdx block girdle, have very different oil pass. I don t believe somebody can adapt it.
Old 03-03-2016, 12:08 AM
  #1261
RDX10's Avatar
Oh I see. Well done sir!
Old 03-03-2016, 04:09 AM
  #1262
Slow98teg's Avatar
You're right. I didn't even notice that before. And I just modified my k20a2 pump for my k24 two days ago lol.
Old 03-03-2016, 08:20 AM
  #1263
KenB350z's Avatar
I'm sure it will get ironed out. I'm mean look, all the guys around here are saying "WHAT YOU MAXED OUT YOUR 1200cc INJECTORS?!?!?, YOU HAVE TO BE PUSHING 400+HP". Now, who ever would have thought we'd see the day?!
Old 03-05-2016, 03:03 PM
  #1264
KenB350z's Avatar
Transmission limits...... The tire noise and redlining is me....
Old 03-05-2016, 03:06 PM
  #1265
KenB350z's Avatar
Tq isn't going to kill the Trans, but I know Hp will.
Old 03-05-2016, 03:18 PM
  #1266
KenB350z's Avatar
Old 03-05-2016, 04:06 PM
  #1267
KenB350z's Avatar
KenB350z and the beast!
Old 03-05-2016, 06:42 PM
  #1268
Slow98teg's Avatar
What did you run?
Old 03-06-2016, 12:44 PM
  #1269
KenB350z's Avatar
14.6 @ 100mph
First run, I got two runs in. I know need to grab some time this month and get more passes in. I'm not completely disappointed, the transmission was waving the white flag.
I did not brake boost, as I didn't know what the car would do. When I did get off the line there was a brief pause which resulted my 2.6 60' foot. After the pause, boost came on crazy, spinning the tires. In first gear after tires spun, there was the redline; which I was bouncing off of. It seemed that I was reaching the transmission limits, there was a pause or hang-up on the top of ever shift. My mechanic said, "I was probably overloading the tq converter".
So, I'm going to say; the transmission is pretty close if not to it's limits. Which we don't know what that is just yet. I will have to get it dyno, to get the numbers.
Old 03-06-2016, 01:09 PM
  #1270
KenB350z's Avatar
Current setup, upgraded turbo and stock.
Old 03-06-2016, 10:29 PM
  #1271
KenB350z's Avatar
I've noticed from my 2012 time slips that I gradually got faster with every pass that I made here in there. Sometimes I would mess up; however, it took more than one or two passes to get where I need to be. So I'm under the impression that I don't spend enough time at the track. If the track conditions are horrible and I'm end up waiting in line forever, I only get one or two runs in and I'm going home. During this 2012 run that I did, I was nearly running back to back. It was that quick; therefore, I went from a 15.6 to a 14.9. Which is pretty good almost a second off. So I guess I just need to spend more time at the track and keep my tuner informed. But the car is so fast! Maybe I need to break boost more, I was not brake boosting that night cuz I did not know what the power was going to do to the transmission. Obviously we did see that it was spinning and redlining. I was just in sport mode with the transmission doing everything on its own. The transmission freaked out when I got all that power down (WOT) and it just start redlining and it hesitated to shift.
I know after the fuel system and we get more power, we definitely are going to need a new transmission, I mean that's all I have until we see something blow up.
Let me know your thoughts because I'm open to any suggestions or criticism or whatever is going to be thrown at me.
Old 03-06-2016, 10:35 PM
  #1272
KenB350z's Avatar
Weighing in at..
Old 03-08-2016, 11:50 AM
  #1273
DRR98's Avatar
You found the weak link!
Old 03-09-2016, 10:00 PM
  #1274
Haré romel's Avatar
Hi ken, I have the same thing with my transmission (pause or hang-up on the top of ever shift). I resolve:
calibration-throttle-overrun cutoff map high cam (cut) 4000=0.506 6500=0.506
calibration-throttle-overrun cutoff map high cam (recover) 4000=0.546 6500=0.546
cutoff boost when you shift. (try and tell me). number could change, you have build rdx than me. Talk to your tuner.
__________________________________________________ ______________________
KenB350z (03-10-2016)
Old 03-10-2016, 02:45 AM
  #1275
KenB350z's Avatar
Yup, my mechanic took it for a spin tonight! LQQk!
Old 03-10-2016, 10:52 AM
  #1276
KenB350z's Avatar
Hey man, I really do appreciate you coming forward with that information. Not a lot of people on here come forward with their problems, issues or anything that's going wrong with their car. I don't know what they are afraid of. You shouldn't have to be afraid to post any problems or issues because of what people might think or say. Well, they're not going to be judged here at least not by me. So don't be afraid to post any issues or problems that you are having with your car. I'm here to help in any way I can. Obviously this member is here to help as well. Man much appreciated thanks for posting that.
Haré romel is ok in my book. (I do have a little black book)
Old 03-15-2016, 02:44 PM
  #1277
KenB350z's Avatar
Thanks RDX10 for coming through!!
Old 03-16-2016, 01:39 PM
  #1278
RDX10's Avatar
Phew! I was going to text you today and ask if it came in, I was starting to get antsy! No worries, glad I could help!
KenB350z (03-17-2016)
Old 03-17-2016, 10:23 PM
  #1279
KenB350z's Avatar
Late night.....
Old 03-19-2016, 01:03 PM
  #1280
KenB350z's Avatar
Thanks slow98teg for the recommendation. The piston's and valve's look great!
Quick Reply: K23a1 Build
