Fog light replacements???
Old Apr 12, 2010 | 07:54 PM
JMJ3rd's Avatar
'06 RL Tech
Just had a fog light busted out by a rock! Anybody do any upgrades, besides the HID bulb change out, to another style of fog light? $200+ for one light from the dealer to install.
Old Apr 12, 2010 | 08:18 PM
BigHatch's Avatar
not an SUV ...a Big Hatch
Dang! maybe i should invest in some protective film...
You mean like a whole different fog light unit? like a PIAA projector or something of the kind?
Old Apr 12, 2010 | 08:20 PM
JMJ3rd's Avatar
'06 RL Tech
Yeah. Something completely different if possible.
Old Apr 13, 2010 | 03:30 PM
1TSXer's Avatar
Resident Metal Head
On ebay someone has an OEM RH one for $45 and another for $99. I also had seen a LH for $99. Not too bad if you just need one.
Old Apr 13, 2010 | 03:51 PM
brizey's Avatar
I have a busted one two. I got quoted a little over $200 from the dealer, too.
Old Apr 13, 2010 | 09:38 PM
JMJ3rd's Avatar
'06 RL Tech
Thanks! I'll check it out.
Old Apr 14, 2010 | 07:15 AM
lilcasino's Avatar
you can pick one up online oem new for 98$ but, I got a drivers side used via ebay for 65$
Old Apr 14, 2010 | 09:15 AM
brizey's Avatar
The labor is where the dealer gets you. And from what I can tell it will be a pain in the rear to change.
Old Apr 14, 2010 | 09:21 AM
1TSXer's Avatar
Resident Metal Head
^They are way easy to do yourself. It just requires removal of the bumper. A few screws, a couple of bolts and plastic clips and a tug on each side and it pops right off.
Old Apr 14, 2010 | 03:51 PM
JMJ3rd's Avatar
'06 RL Tech
Looking at the passenger side one that's there.
Old Apr 15, 2010 | 08:30 AM
brizey's Avatar
I may just order the one for $98 and do it myself, then.
Hmm...then I'll be tempted to do HID's.
Old Apr 20, 2010 | 10:17 AM
Thillan's Avatar
5th Gear
fog lights arent that bad stock..
Old Apr 20, 2010 | 01:21 PM
brizey's Avatar
They work fine. The color just does not match very well.
I have the 6000K HID's from HIDNY, and the foglight assembly replacement is on its way.
Old Apr 20, 2010 | 01:25 PM
1TSXer's Avatar
Resident Metal Head
True,but protective lens film (Lamin-X) burns with the hot stock halogens. The HID's do put out more light and burn cooler so you don't have to replace the film very often.
Old Apr 20, 2010 | 02:50 PM
BLACURA SUVND9L's Avatar
What temp are the RDX factory low-beams?? I am also looking to get HID's but want to match the low-beams as close as possible so it looks uniform.
Old Apr 20, 2010 | 03:09 PM
wspy's Avatar
2008 Acura RDX
^^4500k
Old Apr 20, 2010 | 09:05 PM
thx
Old Apr 21, 2010 | 08:53 AM
brizey's Avatar
4500k is tough to find in the aftermarket. Most HID kits jump from yellow 3000K to 6000K from what I had seen, so I figure 6000K is the closest.
Old Apr 27, 2010 | 09:16 AM
buMzy's Avatar
I think I saw your post that you fixed your fog lights on another topic Brizy but I was wondering if you or anyone else ever looked into a plastic lens for the RDX. I saw a picture on a TL around here and his 10k fogs looks very sharp!
Old Apr 27, 2010 | 09:21 AM
brizey's Avatar
There is another thread on here somewhere about protective film for the foglights.
Edit: Found it: https://acurazine.com/forums/showthr...fog+light+film
Old Apr 27, 2010 | 07:23 PM
buMzy's Avatar
Whoops, wasn't clear, I had meant the entire thing. Not just a film. The entire housing also.
Found the pic.
https://acurazine.com/forums/album.p...ictureid=15549
Lenses are plastic?
Old May 11, 2010 | 11:22 PM
K23A+F22C's Avatar
I just just PIAA ion fog light blub. You gain more light in the fog and snow.
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
theinsvnity
Sep 10, 2015 10:22 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
