18" rims replacement and offset
Old Mar 5, 2008 | 09:11 AM
Acura604's Avatar
2024 RDX A SPEC
If you were to replace your 18" stock rims with a different set of 18s.. would they still be as 'tucked' in as our stock rims? assuming stock offset is 45... with an offset of 42 on some other 18s.. they would probably be a bit further out with our stock tires?
Old Mar 5, 2008 | 09:55 AM
MMike1981's Avatar
big shot.
get a wider than stock rim to fill the gap better, if the replacement is the same size it will most likely appear the same way (assuming the offset doesnt switch much)....but why go 18's again? if ur gonna change out the rim, go at least a +1
Old Mar 5, 2008 | 10:38 AM
Acura604's Avatar
2024 RDX A SPEC
yah...i was just looking for a cheap fast and dirty upgrade to get the rims to stick out more and saving cash by using the stock 18" tires.
Old Mar 5, 2008 | 09:57 PM
Patronus's Avatar
If you go with 8" wide rims and, for example, 40mm offset, that will put the outside face of the wheel [1/4" (wheel width) + 5mm (offset)] ~= 1/2" further toward the outside of the car.
I would highly recommend against using spacers.
Old Mar 6, 2008 | 10:35 AM
Acura604's Avatar
2024 RDX A SPEC
opinions? or are these just too blingy and ugly?
18x8
offset 42
5x114.3
Old Mar 6, 2008 | 11:46 AM
Patronus's Avatar
I think chrome wheels are a highly personal taste thing.
Personally, I think most of them (including these shown) look like speed-shop wheels.
Old May 24, 2014 | 10:24 PM
GA ark's Avatar
What do the '07 18" stock rims weigh? Anybody? I'm just being lazy and am not researching this myself...
Old May 26, 2014 | 10:11 AM
bluecarbonfiber's Avatar
WTF?
i think i read they weight around 27 lbs without tires
rseb4agze
May 3, 2016 07:41 AM
lland
Oct 4, 2015 04:47 PM
Hau_nguyen91
Sep 6, 2015 12:53 PM
nuldabz
Sep 3, 2015 05:49 PM
bailey24
Aug 31, 2015 05:38 PM
