Tranny Cooler?
Originally Posted by DreamRDX
Does the RDX come with one stock? I plan to tow a small trailer with a snowmobile on it and I would like the extra piece of mind with a tranny cooler. Anybody?
There is a sensor that will go off when your tranny temperature goes above normal. So if you don't see it going off, there is no point to install a cooler. Honda had transmission issues with 2001-2003 CL/TLs, and its been fixed ever since.
also all auto trannys always go through the stock rad as well.
I would just flush your coolant and put in high quality coolant so it can take the abuse from the excess heat.
Also change the tranny fluid before any long hauls.
I understand you are suppose to use high quality coolant and a light will come on when it over heats, but why not add a cooler for added protection?
Originally Posted by sasair
I suppose because it's not really necessary....
So what your saying is you would rather have it over heat, flash a light on the dash over have a tranny cooler on there with no overheating and no light? Im just trying to figure out your resoning.....
Of course if you're really worried about it then go ahead and put one on for peace of mind if nothing else. I was just offering up an opinion.
It is not cooled by coolant though; it is a fluid to air heat exchanger that's dependant on airflow for cooling. So long slow uphill climbs will generate higher trans temps, but at that point those screamin' electric fans should be pulling plenty of air across the heat exchangers.
You are more likely to get an SH-AWD overheat, because it is air-cooled. This will stay on even if you pull over and let the differential cool. You have to switch the ignition off and restart in order to reset the message.
We're rated for 1500 lbs, so a snowmobile should be no problem.
Originally Posted by 737 Jock
Yes it does; all RDXs come stock with an ATF cooler.
Looking in the LF wheel well in front of the wheel you can see the two banjo bolts for cooling feed and return lines. The upper bolt is the return line. The 2" round housing it attaches to is the filter. Just below it is the feed line.
Pham Alvan
May 18, 2021 06:48 AM
Pham Alvan
Mar 16, 2016 09:17 AM
lanechanger
Oct 13, 2015 10:56 AM
