LED Strip Lights
Old 12-28-2008 | 06:20 PM
littleblazer's Avatar
LED Strip Lights
What you guys think about this?
Old 12-29-2008 | 10:33 AM
bAek-sU's Avatar
He who laughs, last didnt
where did u tap the wire into?
Old 12-29-2008 | 11:00 PM
Tap from Front sidemarker Lights + Front sidemarker has LED too.
Old 01-09-2009 | 12:16 AM
superpowers's Avatar
looks good
curious...where did you buy that grill and the LEDs?
Old 01-09-2009 | 12:35 PM
R*D*X*'s Avatar
+ 1 on the grill... where did you buy it?
- 1 on LEDs. it will probably look better if the strips is longer or 1 straight line instead of two small strip..
Old 01-09-2009 | 06:19 PM
Pilot automotive Grill have to cut and fit. local auto part store
Have then on upper and lower area under license plate.
LED Stip got it from oznium.com
Old 07-23-2009 | 12:01 PM
I decided to put strip light above the headlight housing.
It look better at night time....
Old 08-04-2009 | 09:51 PM
Night Time Shot with 3000k Fog lights
Old 08-06-2009 | 08:16 PM
wspy's Avatar
2008 Acura RDX
Cool. Give us a pic of it to see how you mounted it. Like with the hood open.
Old 08-06-2009 | 09:15 PM
Mount it with 3M double tape closer to edge, tap the wire from corner yellow light.
I'll get some picture when I get chance.
Old 08-07-2009 | 01:47 AM
JMJ3rd's Avatar
'06 RL Tech
I like the 3000K's! That's what I'm going to do next. Who's did you use?
Old 08-09-2009 | 02:40 PM
Got use to get it from hidny.com before but I started order from http://www.ddmtuning.com is cheaper $39.99 for kits. I got raptor ballat on my fog light it works fine.
I'm ASE mechanic and do sell to my customer on the side starting 100.00 installed.
Extra money to spend on BS....
Trying to upgrade exhaust for my RDX but no luck yet. worse come to worse I'll make it myself if I have to... do you know anybody?
Old 08-09-2009 | 06:20 PM
bgillette79's Avatar
Too many different colors in my opinion. Either they all should look the same, or the fogs should be yellow.
You have 3 different shades of blue/white
Old 08-10-2009 | 06:25 PM
JMJ3rd's Avatar
'06 RL Tech
This one?
http://www.ddmtuning.com/index.php?p...=102&parent=85
Old 08-10-2009 | 08:41 PM
Yes
Old 08-11-2009 | 04:42 AM
JMJ3rd's Avatar
'06 RL Tech
Thanks!
Old 08-13-2009 | 07:57 AM
Chronic14's Avatar
Interested in pics. Looks great.
Old 12-12-2009 | 08:15 PM
pdpgps's Avatar
Not really a huge fan. Those LEDs are meant to be in addition to day time running lights or to replace them? It's too much going on. Plus they aren't really in a distinctive location or pattern like the audis, saabs, and mercedes.
Old 04-19-2010 | 05:26 PM
xpmax's Avatar
7th Gear
Old 04-30-2010 | 10:21 AM
param7's Avatar
Nice hookups. You should get the LED switch-back turn signals for the corners.
Old 04-30-2010 | 11:46 AM
ucsmfu's Avatar
is the led strip on the inside or the outside ?
Old 05-03-2010 | 07:38 AM
wspy's Avatar
2008 Acura RDX
I believe he used some form of double sided tape and mounted it on the out side of the lamp housing. If you lift the hood and look at the top of the lamp housing at the forward edge you'll see a little lip where I think he just stuck the LED strip.
We've been asking for pics but.....
02-25-2020 09:57 AM
oyayjoe
01-01-2019 10:17 PM
Greengecko
09-16-2015 08:19 PM
oyayjoe
09-12-2015 04:40 PM
drewdeezy03
09-03-2015 08:04 PM
Quick Reply: LED Strip Lights
