LED Strip Lights
What you guys think about this?
https://acurazine.com/forums/picture...pictureid=6179 https://acurazine.com/forums/picture...pictureid=6178 |
where did u tap the wire into?
Tap from Front sidemarker Lights + Front sidemarker has LED too.
looks good
curious...where did you buy that grill and the LEDs? |
+ 1 on the grill... where did you buy it?
- 1 on LEDs. it will probably look better if the strips is longer or 1 straight line instead of two small strip.. |
Pilot automotive Grill have to cut and fit. local auto part store
Have then on upper and lower area under license plate. LED Stip got it from oznium.com |
I decided to put strip light above the headlight housing.
It look better at night time.... https://acurazine.com/forums/picture...ictureid=17697 |
Night Time Shot with 3000k Fog lights
https://acurazine.com/forums/picture...ictureid=18356 |
Cool. Give us a pic of it to see how you mounted it. Like with the hood open.
Mount it with 3M double tape closer to edge, tap the wire from corner yellow light.
I'll get some picture when I get chance. |
I like the 3000K's! That's what I'm going to do next. Who's did you use?
Got use to get it from hidny.com before but I started order from http://www.ddmtuning.com is cheaper $39.99 for kits. I got raptor ballat on my fog light it works fine.
I'm ASE mechanic and do sell to my customer on the side starting 100.00 installed. Extra money to spend on BS.... Trying to upgrade exhaust for my RDX but no luck yet. worse come to worse I'll make it myself if I have to... do you know anybody? |
Originally Posted by littleblazer
(Post 10328172)
https://acurazine.com/forums/picture...pictureid=6179 https://acurazine.com/forums/picture...pictureid=6178 You have 3 different shades of blue/white |
(Post 11189056)
I'm ASE mechanic and do sell to my customer on the side starting 100.00 installed. Extra money to spend on BS.... Trying to upgrade exhaust for my RDX but no luck yet. worse come to worse I'll make it myself if I have to... do you know anybody? http://www.ddmtuning.com/index.php?p...=102&parent=85 |
Yes
Thanks!
(Post 11182873)
Not really a huge fan. Those LEDs are meant to be in addition to day time running lights or to replace them? It's too much going on. Plus they aren't really in a distinctive location or pattern like the audis, saabs, and mercedes.
(Post 11175171)
Nice hookups. You should get the LED switch-back turn signals for the corners.
is the led strip on the inside or the outside ?
I believe he used some form of double sided tape and mounted it on the out side of the lamp housing. If you lift the hood and look at the top of the lamp housing at the forward edge you'll see a little lip where I think he just stuck the LED strip.
We've been asking for pics but..... |
