Wiring an amplifier
Old Mar 6, 2014 | 10:32 AM
LongIslandRDX's Avatar
Wiring an amplifier
Hey All,
I recently replaced all of the door speakers with Infinity Kappas and for some reason the subwoofer lost it's thump. My assumption is the speakers are drawing power from the subwoofer. So I am adding a 3 channel JBL GTO - 3EZ amp to the set up. I will power the front doors and subwoofer (Installing a Kicker in the factory location) with it. The stock amp will continue to power the rear doors, rear pods and dash.
My question is what color is the remote turn on wire at the stock amp? I've spent two hours reading the audio and DIY sections and have no answer to this (outside of sticking a wire to the fuse box).
Thanks and I appreciate any help.
Old Mar 6, 2014 | 11:41 PM
bluecarbonfiber's Avatar
WTF?
not sure if you have base or tech pack but if i remember correctly its the pink wire that is actually from the head unit and not the amp, take a voltage tester to it and do the on off switch to confirm
Old Mar 7, 2014 | 07:18 AM
I have the tech package. I was hoping this would be easy and not having to get behind the dash. Shouldn't that wire make it's way to the amp to turn it on when the key is turned to accessory?
And thank you for the response.
Old Mar 7, 2014 | 09:01 AM
WTF?
i checked the wire diagram and i dont see one on the amp only the head unit..
Old Mar 7, 2014 | 10:24 AM
Thanks for your quick responses!! I'll let everyone know how it turns out.
Old Oct 20, 2016 | 01:59 PM
Nate.E's Avatar
Question
Hey did you figure out which is the remote wire? I have an '09. Is it the same colour for all 1st gens?
Old Dec 28, 2016 | 09:44 AM
drakescherer's Avatar
Its easy enough to make one yourself, wire a switch inline from 12v and put that switch wherever. You then can turn it on and off as you please but will have to remember to shut it off after you're done.
If thats annoying, find yourself a fuse under the drivers side area that is hot while the car is running (as in has power, not literally hot. if its literally hot you have an issue), then buy an add a fuse module, swap that in making sure to keep the same fuse rating as the original fuse and use a low amp fuse for the new circuit youll be making
If both of those are too much of a pain, then you can get level converters (LC2i) that detect when there is a high level input on the RCA side and will provide a remote signal to your amp to turn on as soon as the high level is detected. (this is the option I have)
4drviper
Apr 23, 2025 07:13 PM
Acura604
20
Aug 5, 2017 12:55 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
