Where are the stereo's crossovers located?
I have an 07 Tech and I'm about to swap out the four front door speakers. Does anyone know where the factory crossovers are located?
Thanks.
Thanks.
Bump. I've taken a look at the Service Manual and can't find a reference to crossovers anywhere...but wouldn't crossovers be necessary for the OEM door speakers which are split between tweeters and woofers? Likewise, I've bought component replacement speakers with their own crossovers, but I don't see how to wire them in.
Thx.
Thx.
wspy: I think you're right. So how do you upgrade the OEM tweeters, drivers and crossovers in the doors if you can't replace the OEM crossovers? Obviously I could just plug the speakers in and not use the new crossovers but isn't that a bad idea in terms of sound quality? FWIW, I bought JBL GX600Cs (once I narrowed down options that were both component speaker and 2 ohms, there's precious few options).
Thanks.
https://www.crutchfield.com/S-gJ8FlP...BL-GX600C.html
Thanks.
2008 Acura RDX
Shouldn't really matter if you just install the JBLs without their crossover because the stock factory system has done it (freq split) already. Your main concern is that the impedance is correct at 2 ohms.
Thanks.
Thanks.
Hi, I was just curious, but did you ever install the speakers without the passive crossover? If you did, how did it sound?
savclaude
01-21-2013 01:42 PM
Westside_TL
03-18-2012 04:35 PM
flags
10-25-2010 04:48 PM
