Sub woofer not woofing
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I have a 2008 RDX. Suddenly the stereo system has gone "tinny" and quiet. We think the sub woofer has stopped working. Has anyone else had this problem? Thanks.
I'm experiencing low subwoofer output as well
Eilidh - I'm curious to see if you've made any headway on this problem. I have a 2009 RDX. Even with the subwoofer set to max I have low bass output. Very disappointing, especially compared with the output on my 2004 TL. I'm due for my first maintenance, so I'll ask the dealer to take a listen.
Anyone get their audio problem fixed? I have a 2009 RDX and my sub is pretty weak too...The lows aren't really there. I'm wondering if the sound system is too weak to push everything by itself...maybe a seperate sub?
I don't have an update on my status. I did have it in for a scheduled oil change and asked about the weak bass output. Of course they (the dealer) said that there isn't a problem.
Is it weak NOW, or has it always seemed weak?
Best way to test if there is ANYTHING coming out is put a song with bass and then use the stock headunit to turn the bass from -6 to "OFF" and see if there is ANY difference in the bass response.
Carbon Bronze Pearl 2008
I have a base 2008 RDX and the sub-bass shakes the car with a heavy bass song! I have the lows set to +2 and the sub set to +3. Any higher and it's too much. There must be something wrong if you have little or no bass. My stock system (non-tech) really kicks the bass.
Boost Enthusiast
It's a fatty kit. It'd probably be better to call it a full setup rather than a kit. I basically have two 12" with a 2000watt amp:
Power Acoustik TS1920-2 Two Channel 1920W with plasma sphere built in
Two 12" Kenwood KFC-W3010 1000W 4-Ohm Subwoofers
Boost Enthusiast
Boost Enthusiast
The basic setup was keep everything stock and just tap into the stock sub. I didn't have much of a budget but it still packs a punch for only 600 bucks.
Boost Enthusiast
Hey,
Sorry for the guys who want pics of my system. Been busy with classes. Hopefully this weekend I'll take pics when I turn the subs around so they fire forward. Less vibration on the back door, more power to the front. Since the RDX is a single cabin, should sound the same either or.
Remove the privacy rear deck lid for better bass.
Boost Enthusiast
Yea, I thought about it, but that's the point of having the "privacy" rear deck lid. I don't want random people looking into my car and get the idea of copping my system. I feel you though, it does sound better if I take it off, but for the normal I just leave it on.
You should NEVER keep anything of value, even if it looks like it might be, in your car.
akbears15
15
11-05-2015 07:06 AM
kb1rl
09-30-2015 10:17 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
