Installing USASpec Bluetooth module. Location of XM Tuner in Canadian 07 Tech?
Old Jul 31, 2020 | 06:26 PM
nemoD's Avatar
I ordered the USA-Spec Bluetooth module for my Canadian 07 Tech (BT-45 ACU). The tuner is supposed to be behind the glove box and there's nothing there. Any Canucks out there that have been faced with this issue? Is it possible there's a Canadian exploded parts diagram I can consult? I'll probably end up removing the radio but I thought I would ask before taking anything apart.
Thanks.
Old Aug 4, 2020 | 06:27 PM
CSmoney28's Avatar
CSmoney28
Check the passenger side foot well on the left side. There should a door you can pop open with a flat head. Let me know if it works out for you...
Old Aug 9, 2020 | 06:46 PM
Rustyrock's Avatar
Thanks.
Where did you order the module from? I’m having an HFL problem and from what I’ve read it’s likely the module. It is on the passenger side console. I’m not sure if the entire DVD player needs to come out to access it though
Old Oct 16, 2020 | 06:56 PM
nemoD's Avatar
Hey, I just realized I didn't respond to your question. The HFL is behind/aft of the DVD and amp (to the right and below the tranny shifter), it's easy to access and unplug which I have done as quite a few people have noticed it can drain the battery, and with an after-market Bluetooth system it can only cause problems left plugged in. I ordered a USA Spec BT45-ACU but it looks like the right one is the BT45-HON3. HTH.
Siochao
Oct 29, 2019 03:00 PM
mazen222
Dec 27, 2016 09:03 PM
sctlenz
Sep 10, 2007 09:33 AM
SilverJ
23
Mar 17, 2006 11:22 AM
