Climate control diagnostics mode
Old Jul 26, 2020 | 08:49 AM
Garcub's Avatar
I have an 07 RDX and have searched and come up with info for MDX and TSX and such but not RDX. Maybe I didn't search correctly. I wanted to know how to enter HVAC diagnostic mode and the table of error codes. Neither my driver or passenger side temp controls do anything. Wanted to fix it before winter comes so I can have heat. Blend motor on drivers side doesnt respond to temp up or down...gavent checked passenger side but air temp doesnt chahe there eithet.
Thanks!
Old Jul 26, 2020 | 10:42 AM
Altair's Avatar
Originally Posted by Garcub
I have an 07 RDX and have searched and come up with info for ... not RDX. Maybe I didn't search correctly. I wanted to know how to enter HVAC diagnostic mode and the table of error codes...
Thanks!
Welcome to the board!
try this, msg#47
https://acurazine.com/forums/1g-rdx-.../#post16602520
I prefer to search using "advanced", I can the restrict the forums searched, etc.
Hope this helps!
Old Aug 4, 2020 | 06:25 PM
CSmoney28's Avatar
CSmoney28
Please check all of the fuse boxes including but not limited to both under the hood on the driver side as well as the one under the drivers side dash board. Get a fuse remover tool and new fuses. Look on the Acura parts store if you need a diagram of anything. Under the fuse cover should show you what each fuse does. Let me know if you need help...
misantor
Jun 29, 2020 03:13 PM
Redryderm
Apr 15, 2017 02:47 PM
sternmd
1G RDX Problems & Fixes
Jun 6, 2015 05:18 PM
Rod406
Oct 8, 2011 04:50 PM
