bluetooth not seen by the phone
Old Sep 15, 2018 | 11:21 AM
mili's Avatar
4th Gear
Hi,
I have 2008 rdx with technology package . For some reason my phone or any other phone cant see a bluetooth from acura. I try everything . Delete everything and restart all over. no success . Then i read that I need to reset bluetooth which I do still nothing. Any advise will be appreciated.
Thank you,
Old Sep 16, 2018 | 09:14 AM
WellHellWtvr215's Avatar
Are you the first owner? Did you check to see if the fuse is still there for the Bluetooth? Our cars are known for sometimes developing a battery draw from the Bluetooth module. Someone prior to you may have pulled the fuse for it.
If that's the case, you may need to replace the Bluetooth module to get rid of the battery draw as well.
-Shane
Old Sep 16, 2018 | 10:03 AM
mili's Avatar
4th Gear
No I am not the first owner . Everything was working till the last week . when i turn bluetooth on for the search it cant see Acura bluetooth. I try with different phone, no success . So I delete everything from the phone menu and rest bluetooth but still nothing. It is not visible by any phone. My only guess is that bluetooth module stop working. Is there any way to check it out?
Thank you,
zed88
Nov 11, 2015 12:30 PM
acura2009
Jul 4, 2009 12:02 PM
atomarchio
Feb 20, 2006 12:55 PM
mobilezen
147
Oct 20, 2005 11:32 PM
Novice
Jan 20, 2004 12:22 PM
