2010 RDX iPod Integration
If I have my iPhone (3G) plugged into the USB port and am listening to the iPod using the interface (not the Bluetooth audio streaming) and I start or restart the vehicle, the sound stops after about 20 seconds.
The display is still showing the details for the track etc., but no sound. The only way I've found that I can get the sound to come back is to unplug the cable from the iPhone and plug it in again.
It's not a huge deal, but a little annoying, as usually I've begun driving before the sound drops out, and then have to mess with the cable.
Anyone else experiencing this with their 2010s?
Yep. Annoying.
Have you upgraded the iPhone OS yet? Some people have reported problems with the integration after upgrading. My wife's iphone is updated, and it was slow to show track names, playlist names, etc. But it works.
I have a 2010 TL that exhibits the same problem using an iPhone 4; I presume navigation & audio electronics are standardized throughout all models.
Actually, it's more than just the 'if car is restarted, no audio from iPhone'. Sometimes (fairly rarely) while playing back from the iPhone all audio will cut-out spontaneously. Also, sometimes audio levels will drop significantly, and only selecting a different audio source (such as XM) and returning to the iPod source will fix it. This seems to happen more frequently when the nav computer is active and directing to a destination (and I'm not talking about the volume decrease when the nav voice speaks; talking about during periods when there should be no volume decrease).
None of this happens on an iPod classic.
Notice that when you plug your iPhone in you probably get a compatibility warning notification on the iPhone. This means that the vehicle is using an old protocol to talk to the device. I suspect that this might have something to do with the iPhone issues. In any case, Acura's claim that the iPhone is supported is stretching the truth a little bit. It works, just not very well.
Had a 10 Rdx Tech loaner today, could not figure out how to pause my ipod, how is it done?
I switched to other sources and it didnt pause. The track was still playing when I came back to it. Sometimes it would still be playing after turning off the radio.
Also the sound volume is very low if you change to FM
4drviper
Apr 23, 2025 07:13 PM
TLguy42
Sep 26, 2015 11:27 AM
