Wheel question
Old Jan 16, 2008 | 03:46 AM
  #41
737 Jock's Avatar
haole kama'a-ina
Originally Posted by JMJ3rd
737,
Would there be any negative issues besides rotating tires if I went with 9" in front and 10" in the rear?
http://axiswheels.com/wheels.php?id=gt-r
The GT-Rs are 20x9 front and 20x10.5 rear. The Axis spec sheet doesn't show offset, so it's difficult to determine if the extra 2" width rear would be an issue. They refer to fitment considerations in the Staggering FAQ, so I imagine they will advise you when you call.
Next; are your objectives looks or performance? From the Axis FAQ:
A popular trend is coming back for both cars and trucks is called "staggered" or "staggering". Staggering wheels involves using wheels of different width and/or diameter on the front and rear of the vehicle for a more stunning or aggressive look.
If you are going for the aggressive look and the staggered wheels fit, you are good to go....well, almost. Remember, the AWD system on the RDX constantly overdrives the rear axles via the SH carbon clutches. The overdrive applies continuous wear to the clutches and is tuned to operate 4 wheels that all have the same mass. Increasing the relative mass of the rear wheels will probably increase the wear on the clutches and the resulting SH-AWD temperature. How much extra wear and will the heat trigger a Diagostic Trouble Code? Maybe Acura could answer that.
It is certain though, that staggering the wheel size front to rear will cause problems. (I know you didn't suggest this, but Axis did.) The tire rolling diameter must be equal to avoid stress on the drivetrain.
Regarding staggering effect on performance:
The stock RDX is a transverse engine, front drive chassis with less than optimal polar moment (57/43 dist). It understeers off throttle, (compared to the X-3 with a longitudinal 6 cylinder and near perfect 51/49 dist). Fixing understeer requires larger rear slip angles, usually achieved with a stiffer rear anti-roll bar.
Staggering increases the width (and shortens the length) of the rear contact patch, increasing the lateral grip, making it more difficult to generate oversteer both off throttle and with the SH-AWD. The stiffer rear anti-roll bar could be brought into play here.
The higher unsprung weight and longer moment arm of the rotating mass on 20" wheels is more resistant to directional changes. The guys with 20s generally don't report much of a difference in butt feel though. Hope this helps.
Old Jan 16, 2008 | 08:26 PM
  #42
JMJ3rd's Avatar
'06 RL Tech
Yes it helps. Thank you for your research, knowledge and TIME. I'll probably stick to the 9.5's.
Old Mar 15, 2008 | 05:37 AM
  #43
LuvMyRDX's Avatar
Bump for this thread!! I'm researching wheels and this thread helped tremendously. It definitely should take its place back up top. You know your s**t, 737.
Old Mar 15, 2008 | 10:27 AM
  #44
SinCity's Avatar
Ditto. 737 is a great resource.
Old Mar 15, 2008 | 12:57 PM
  #45
Patronus's Avatar
Good bump. This is a very useful thread!
One oddity is that I checked the back of my stock 08 RDX wheels and they are 45 offset! I wonder if different wheel manufacturers provide different offsets or the offset changed from 07 to 08?
Anyway, I just ordered some TSW Montage wheels (18x8-40) to replace the drab-colored, heavy-looking stock wheels. I almost painted the stock wheels a "normal" silver color instead of the "brake dust silver" color provided by the factory, but would still be left with the heavy, inset-too-far look.
I'll post some pics when I get them mounted next week.
Old Mar 15, 2008 | 05:19 PM
  #46
SinCity's Avatar
I thought about using hub-centric spacers to poke the wheel out. The stock wheel is not bad looking. I also agree that I would prefer a "bright" silver.
Old Mar 15, 2008 | 09:43 PM
  #47
Patronus's Avatar
Many people, myself included, highly recommend against spacers. If they are not seated correctly (and it is very hard to tell if they are), the bolts will torque, but the wheel will not seat and, well, eventually can come off.
Go with a wheel with a numerically lower offset if you want to punch the wheels outward.
Old Aug 29, 2010 | 07:10 PM
  #48
boxerjoe's Avatar
Arrow
Originally Posted by champlain
I did put 16 inch element mag on my RDX for winter so I can have more rubber between the road and me.
We have very bad road around here in Montreal.
Hey Champlain,
I am from Ontario and hear your pain - our roads or better yet pot holes are horrible. I just bought a 2011 Acura RDX and last winter bought a set of 16" Acura steelies for my TSX that I traded in. I also got 205/60/16 Michelin Xice2 tires to go with them. Do you know if these tires will work/fit on the RDX? I've been searching for an answer with no luck
Thanks to anyone who can help answer this..
Cheers,
Joe
Old Apr 28, 2012 | 07:12 PM
  #49
Sylvain's Avatar
Originally Posted by OTT-TSX
I am about to get some winter tires for my RDX and had a quick question. I still have a set of 2004 TSX 17 inch alloys with winter tires on them, would these fit my RDX ? I don't care about the tires as I will be replacing them but would the wheels fit ?
I'd like to confirm if the TSX 17inch wheels will be OK or not for a 2008 RDX;
I've been through this thread and am a bit confused now....
Old Dec 27, 2012 | 08:00 PM
  #50
Sylvain's Avatar
Seems like they are working fine...
Old Jan 5, 2013 | 12:22 PM
  #51
Sylvain's Avatar
New link:
Old Jan 5, 2013 | 09:11 PM
  #52
Vividsi's Avatar
That looks really good with white.
Old Jan 6, 2013 | 10:43 AM
  #53
Mr Marco's Avatar
Add Yakima rack with a box, 25% tint on the side windows and you have the perfect ski vehicle.
Old Jan 6, 2013 | 07:39 PM
  #54
Sylvain's Avatar
Thanks guys. I am pleased with the result for a set of wheels I picked up used for $300. I was told that one of them is bent though...
booma1218
May 3, 2016 07:39 AM
lland
Oct 4, 2015 04:47 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
bailey24
Aug 31, 2015 05:38 PM
