Washer Fluid leak
Washer Fluid leak
Seems like exact symptom as this tsb. Should I try asking for goodwill as TSB suggests? Seems like dealer can do it cheap and quickly ($15 parts).
https://honda.oemdtc.com/TSB/B08-023.pdf
Not sure if its necessary remove fender to re-adjust the bolts. Seems like the neck can be replaced by itself without removing the fender. that maybe good enough?
2006 NBP TL MT6/ 02TL-S
Mine was leaking badly. It was a broken plastic part right at the pump where it divides the flow into the 2 little hoses for each side. I had to take the bumper off to get at it. I fixed it with some sealant/glue stuff, let it dry for awhile, and it has been good since.
seems like there is a defect in original part and Acura has updated part for the neck.
If there's a TSB, just take it in
BartmanEH
20
12-17-2019 07:37 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
