Turbo-eye install gone horribly wrong.
Old Sep 10, 2022 | 10:47 AM
feralcomprehension's Avatar
Qualified Observer
I dropped the inconveniently non-magnetic stainless-steel hex adjuster that connects the new turbo eye to the actuator. It didn't make it to the ground and I cannot find it with mirrors, a bright flashlight and patience. Assuming I get to the point where I give up, any tips on how to find a replacement? NFW is Acura or Ace Hardware going to have one...
Thanks in advance; hating myself atm.
Could buy this off the Bay; $108 adjuster, yow.
Old Sep 10, 2022 | 04:44 PM
Qualified Observer
Current plan:
Buy tapped hex stock w/ one side too small, punch out too small wrong-way threads, tap w/ correct left hand thread, trim to length, install.
My advice at this point is to avoid dropping this relatively small and massively bespoke part when repairing your turbo actuator.
Old Sep 13, 2022 | 07:09 PM
Qualified Observer
New part is made and everything is buttoned up, just waiting for the rtv at the valve cover to harden up. Fingers crossed.
Old Oct 23, 2022 | 08:14 AM
Qualified Observer
Quick update- the saga continues. The truck runs but is still coding. I started with my ersatz coupler as tight (shortest package) as possible and have gone about as long as possible in one-turn (which I believe will result in a 2mm length change) increments without ever eliminating the coding. I also had a misadventure with replacing the spark plugs which I'll describe elsewhere.
Today I'm going to go a half-turn shorter, reset the codes, and proceed shorter in one-turn increments (the initial half-turn ensures my adjustment points on the way up will be exactly 180*/1mm space from the spots I tried on the way down). I can't imagine the factory install tolerance is tighter than +/- 1mm, but Honda...
Old May 20, 2023 | 01:01 PM
Qualified Observer
And still no relief. I lost the new-made adjuster hex after weeks of dinking around with it so now I've purchased another. If someone could please give me a rough estimate of the length of the factory adjuster I would be greatly appreciative.
Old May 27, 2023 | 09:53 PM
hues10's Avatar
Would help you if I knew what/where the part is located. Do I have to take anything off to measure it?
Frshcu2
2G TSX Performance Parts & Modifications
Apr 17, 2017 09:25 AM
JBlueCLS6
Sep 21, 2006 11:01 AM
blo2ck
Aug 2, 2003 08:38 PM
Napsoner
Oct 25, 2002 06:40 PM
