TPMS error/malfunction?
Old Jun 16, 2014 | 07:37 PM
Mild83's Avatar
My lady's 08 RDX TPMS monitor went off the other day. She filled the tires with air to their respective pressure recommendations. The light stayed on for another hour's worth of trips, then went off. It stayed off for the next drive, then went back on.
Any ideas?
Old Jun 16, 2014 | 07:39 PM
Tomtwtwtw's Avatar
On a 2008? Wouldn't be surprised if the battery is going out on one or more of your sensors. They're usually good for 5-10 years depending on your mileage.
Old Jun 16, 2014 | 08:05 PM
Mild83's Avatar
Yeah, 2008 and 69k on it. In all honesty, I've never owned a car with TPMS on it before. Should I just take it to a shop? Or is it a simple fix?
Old Jun 16, 2014 | 11:15 PM
schen72's Avatar
There might be a real air leak. Could be a very slow leak caused by a nail or screw. I would carefully check the entire tire and first rule that out.
Old Jun 17, 2014 | 08:29 AM
Mild83's Avatar
That would suck, I just bought 4 new tires less than 6 mos. ago. The message isn't giving one tire though, it's a system warning.
Old Jun 17, 2014 | 09:59 AM
Tomtwtwtw's Avatar
Sounds about right. I have a 2008 Chevy with 82k miles and I've had to replace two of my sensors over the years. Any tire shop should be able to replace it for whatever they normally charge for mounting a tire - probably 15-25 bucks. Alternatively (and I've done this twice now on my Chevy), if you're almost due for tires just buy a new sensor and tell them to swap it out while they're installing the new tires. Shouldn't cost you anything in labor since it literally takes 3 seconds while the tire is off. Unless the sensors on the RDX radically different than on other cars, a new one should run you 30-50 bucks online, add some if you buy it from a shop.
Lastly you can always go old school and keep a tire gauge in the center console.
Old Jun 17, 2014 | 10:32 AM
mrgold35's Avatar
mrgold35
I had the TPMS go off several times in a three week period and it turned out I had a slow leak both times on the same tire caused by nails.
Only other time I had a problem was extreme cold when the temps were in the single digits. I got the warning on all four tires of 27 psi. I add a few more psi in the winter months now to compensate for those cold days.
I would also check for damage to the sensor. Air compressors can have water in them when they fill your tires or fix-a-flat can damage your sensor. I haven't heard of the TPMS readers on the RDX having malfunctions; sounds like it is a TPMS in the tire issue.
Old Jun 20, 2014 | 07:56 AM
Mild83's Avatar
It's not specifying a specific tire, just saying "malfunction", I believe.
Old Jul 3, 2014 | 07:50 AM
DRR98's Avatar
We have an '11 RDX and get random tpms system malfunction codes even though tire pressures are ok. The dealer took a few visits to figure out it was my wifi transmitter for gauges that is plugged into the obd port causing interference to the wheel signals.
Old Jul 16, 2014 | 06:56 PM
mack1611's Avatar
I've been getting an intermittent TPMS System Error this past week.
Old Jul 16, 2014 | 07:25 PM
dirko's Avatar
Hi Ho: What I interpret from what has been said is that the battery on the wheel sensor is not replaceable?
neuronbob
23
Jul 16, 2019 10:48 AM
bailey24
Nov 21, 2015 08:43 PM
johnalfa
Nov 5, 2015 06:44 PM
johnalfa
Oct 31, 2015 12:55 PM
RobbDizzle
Oct 15, 2015 11:16 AM
