Replacement Keys
Old May 7, 2007 | 02:11 PM
OakvilleRDX's Avatar
OakvilleRDX
Replacement Keys
Has anyone here had to buy a replacement key for their RDX? My coat, along with the keys in the pocket, was stolen at they gym the other day. (I had to nervously check that the car was still in the lot). So now I am down to one set, and have to buy a new one. Also wondering if I should get the car re-keyed, as I continue going to that gym. Thoughts anyone?
Old May 7, 2007 | 02:24 PM
Claire's Avatar
'07 Moroccan Red Pearl
Maybe someone took your coat by accident and will return it? I'd hold off a few days.
Old May 7, 2007 | 03:27 PM
grooks1's Avatar
2007 RDX CGP/Taupe
You should be able to get a replacement key from the dealer. No idea what the cost will be.
Old May 7, 2007 | 04:35 PM
number84's Avatar
I personally would at the very least get the FOB reset. At least the person with your keys just can't test it out in the parking lot. But mind you, there may not be that many RDXs to stick a key into and try.
Old May 7, 2007 | 08:36 PM
sasair's Avatar
I'm sure re-keying the vehicle would be very expensive.
At a minimum, you need to de-register the remotes and re-register the remotes you still have and the new one you buy. I don't think the RDX key is very expensive. I think it was like $35 or so for a blank. Getting the dealer to laser cut it might be another story though....
Old May 7, 2007 | 10:22 PM
rdxsteverino's Avatar
rdxsteverino
I purchased an additional valet key at the dealer for $36.50 (not the switch key). Good chance the charge would be significantly higher if they had to program all of your keys to a new code.
Old May 8, 2007 | 03:10 PM
sasair's Avatar
You can program the remotes yourself for free. A blank key/remote is $45. Not sure how much they would charge you to cut the key though.
Re-keying the vehicle would be very expensive. Probably about $600 not including labor for the ignition, front doors, center console, and glove compartment plus new keys.
Old May 8, 2007 | 10:21 PM
rdxsteverino
I'll bite. How do you program the remotes yourself? Does this method apply to a valet key without a remote?
Old May 9, 2007 | 11:07 PM
sasair's Avatar
I don't remember the exact instructions, but you have to clear all the remote from your vehicle and then reregister the remotes you still have.
Obviously you can't program a remote for a valet ket without a remote. If you are referring to the immobilizer chip, the dealer programs that on the key when they cut it.
Old May 10, 2007 | 03:32 PM
natact's Avatar
searching for accessories on ebay I came across this...
http://cgi.ebay.com/ebaymotors/2-200...20767241QQrdZ1
I don't know if it's more expensive to get a set at the dealer or not...
Good luck.
Old May 10, 2007 | 03:38 PM
number84's Avatar
Good luck.
why would you want one that is "pre-cut"...means you would need to replace the key portion...is this possible and cheap to do?
Old May 10, 2007 | 04:23 PM
natact's Avatar
You're right...What if the keys up for sale are stolen????!!!
Not worth the hassle...best to go to the dealership and see what options they suggest. I just thought it was weird that keys were being sold on ebay.
Old May 11, 2007 | 01:57 AM
sasair's Avatar
To replace the key portion you'd have to order a new remote and key set. Defeats the purpose of that.
The only reason I can see to purchase those on ebay is if you wanted to use the remote for something else. Like on the TSX forum I know they were converting their standard keys to this switchblade style key and they were ordering the remote/key, and replacing the key with their TSX key.
Old May 11, 2007 | 04:42 PM
Rdxowner's Avatar
Got Boost?Rdx/Base/CGP
damn thats not funny..
Old May 16, 2007 | 04:27 PM
Pearlgirl's Avatar
5th Gear
I just ordered a new key (intergrated keyless entry) and I was quoted somewhere around $100. I haven't picked it up yet though.
rockyboy
Aug 4, 2024 10:35 AM
nanos
Nov 12, 2015 08:41 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
ahsm
Sep 9, 2015 08:35 AM
asahrts
Sep 4, 2015 05:55 PM
