Projector bowl removal
Can anyone confirm or not whether the projector assmebly can be removed from the housing with out separating the housing?
Looking at replacing the lenses. Mines a 2012, if that matters?
I am sorry man. This forum is mostly incredibly dead. It appears to have died within the last couple of years. I would have imagined that such a sporty vehicle (not to mention an extension of a Honda product) would have a killer following.
In terms of your question, I wish I could help but I am going to er on the side of caution and say that no, you would have to take the light apart to get to the projectors.
The RDX doesn't seem to be a car that lots of people perform mods on. Maybe as the RDX gets older and used versions become cheap enough for teenagers to buy the forum will liven up. I also check out the RL forum. It's also dead over there, as the RL demographic don't do major mods, and the car is so reliable there's not much to talk about.
But you are correct, I expect within the next 2 years that it will be more affordable and therefore more likely to get modded.
n7plus1, the answer is no. You will have to bake the headlights and rip them apart to remove the projector and replace the lens, but to be honest, the RDX's projector is really nice compared to most (my opinion). Not sure why you would want to go beyond that unless you are doing further modifications to the headlights (complete black out, high beam retrofit, etc.).
thanks fellas...i actually have some TRS TSX-R clear lenses leftover from a previous car i wanted to install in either my car or my wifes...my car is a no go...i guess my wifes isnt any better.
Honestly, just hold on to them till you get a vehicle with really shitty projectors.
Agreed with the above. I also have some ZKW-R lenses I've had around for a while but the RDX has a really clean defined cutoff line with its stock projector / lens setup, I was really surprised and impressed. It seems to be even better than my old TL. It's worlds better than the cutoff from my jag lenses, unfortunately those headlights are a bear to get apart and back together.
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
