Maintenance Schedule
Old Nov 23, 2006 | 09:08 AM
acurardx's Avatar
Base RDX - Carbon Pearl
I am wondering what is the maintenance schedule for RDX (other than oil change). And do we have to follow all those 30K, 60K 90K, etc schedule to keep the warranty/extended warranty valid ?
Old Nov 23, 2006 | 09:47 AM
Skeandhu's Avatar
They may toss the warranty on your engine if you miss an oil change or two, but doubtful that this would affect your warranty on other components such as driveline or electrical... The major checks probably need to be done to comply with warranty; there should be some info about this in the warranty package (I'm guessing)...
As far as schedule, I can't seem to find one apart from this link on the Acura.ca site:
Not really clear unfortunately. Sounds like the RDX will be telling you when to get maintenance done.
Old Nov 23, 2006 | 10:53 AM
Madison3's Avatar
If I understand the RDX manual, Maintenance Schedules are called out by the car itself. The on-board sensors and computers will display the set of maintenance actions (eg. A1, A2, B1 etc.) required. However there are specific time-based maintenance actions if the Maintenance indication doesn't come on before those hard-time limits.
For example, my RDX may tell me to do the A1 maintenance at 5000 miles, but someone else's may come on at 3700 miles. For engine oil, if no maintenance indication comes on after 12 months of ownership replace the oil anyway.
Old Nov 23, 2006 | 11:00 AM
Skeandhu's Avatar
A year without an oil change? Even with Syn oil, that's just scary...
Old Nov 23, 2006 | 12:30 PM
acurardx's Avatar
Maintenance
Thanks for everyone's info. The reason I am asking about it is because I am thinking to purchase the extended warranty. and I want to know whether there is a maintenance schedule requirement for it. As I know some of those RECOMMENDED inspection type of maintenance could cost $300-600 each time. So, if it is required to do so for keeping warranty, several of those appointment could cost as much as the price for extended warranty already !
If I don't have to service my car at dealership, I can ask my mechanic friend to do the synthesis oil change and other maintenance inspection.
By the way, so far I only notice the oil change indicator. I've heard the tech package will tell driver which service schedule is needed as well ? I am wondering it is just preset with KM by dealer (service dept)
Madison3's Avatar
I know, I was apprehensive as well since my experience with previous cars was conventional maintenance with oil changes every 3750 miles.
But I think the one-year between changes is meant for owners putting in very few miles over a year, eg if the car is in storage most of the time.
Old Nov 23, 2006 | 02:38 PM
oblio98's Avatar
WayTooManyAcuras
I'm at 5100 miles and have yet to have a "maintenance" alert/warning/reminder.
Old Nov 23, 2006 | 03:22 PM
orbitwhite's Avatar
When I took a test drive of the RDX, the Acura sales person said no major maintenance until 100K miles. Only need oil changes and brake maintenance until 100K. This should be typical because lots of good cars don't need major maintenance for a long time like the new Accords.
Old Nov 23, 2006 | 04:26 PM
acurardx's Avatar
Maintenance
That's good ! What about timing belt ?
Old Nov 23, 2006 | 06:56 PM
sasair's Avatar
I thought I read somewhere about a low or no maintenance timing chain in the RDX.
Old Nov 23, 2006 | 09:16 PM
Madison3's Avatar
Maintenance call-outs A, B, 1 through 5 doesn't call out for timing belt inspections or replacement. Reminder #2 calls out for drive belt inspection.
Anyway, doesn't the RDX have electronic fuel injection (PGM-FI) so no timing belt?
Old Nov 23, 2006 | 09:39 PM
Fishbulb's Avatar
One has nothing to do with the other. Plenty of cars with fuel injection use a belt instead of a chain.
Old Nov 23, 2006 | 09:54 PM
sasair's Avatar
I found it on Acura's website, the RDX has a maintenance free timing chain.
Old Nov 23, 2006 | 10:09 PM
Madison3's Avatar
Aha, thanks for the clarification, both!
Old Nov 24, 2006 | 08:53 AM
rdxsteverino's Avatar
rdxsteverino
Fishbulb is correct - cars with electronic fuel injection still need a timing belt (or chain). The timing belt/chain synchronizes the rotation of the camshaft with the crankshaft so the timing of the intake/exhaust valves (driven by the camshaft) lines up with the pistons (driving the crankshaft). Electronic fuel injection sets the fuel/air mixture and times its injection through the intake valves into the cylinders.
Old Nov 25, 2006 | 11:03 AM
acurardx's Avatar
Can we use our own mechanic to prefer all the maintenance schedule and still keep warranty valid ?
Old Nov 25, 2006 | 11:07 AM
Skeandhu's Avatar
Just keep the receipts. Maintenance should be done, but it doesn't say that Acura has to do it. As long as a licensed mechanic is doing the work, and you have the receipts to prove the work was completed, you shouldn't get any grief.
Old Nov 25, 2006 | 07:11 PM
c_hunter's Avatar
07 RDX - Royal Blue/Ebony
For that matter, you can do your own maintenance -- doesn't need to be a "mechanic". Just keep all your parts receipts or document the work somehow.
Old Nov 27, 2006 | 01:03 PM
acurardx's Avatar
Maintenance
According to the Acura Plus brochure, we need to follow the Acura's maintenance recommendations oultlined on the owner's manual to keep the warranty valid.
Old Nov 27, 2006 | 01:25 PM
acurardx's Avatar
2007 RDX Maintenance Schedule
Look at Main Item B/B1 , except the oil change and tire rotating, it is mainly inspection. I remember they did something like this on my RSX, it costed $600 !!! This is what I was talking about. If we have to follow their inspection type of maintenance schedule to keep the warranty, 3 of them can cost as much as the extended warranty.
Your vehicle is equipped with the Maintenance Minder system. The on-board computers will calculate when service is required.
One of the most convenient and important features on your RDX is the advanced technology of the Maintenance Minder System. The maintenance requirements for your RDX are determined by an internal algorithm, which considers the engine starting temperature, driving distance and engine RPM. The onboard computer also judges your driving conditions and habits, and then calculates the remaining engine oil life, displaying it as a percentage. The technology of the Maintenance Minder System allows you to enjoy your RDX without the worry of when you are due for your next servicing.
The remaining engine oil life and maintenance service symbols are displayed in either the odometer/trip meter area or in the multi-information display area. As part of the Maintenance Minder System, a separate "wrench" icon also appears indicating that required maintenance service is due. Based on engine operating conditions, the onboard computer in your Honda calculates the remaining engine oil life. When the remaining oil life is approximately 15%, the Maintenance Minder will indicate that an oil change is due soon. When it reaches 5%, the system will show that an oil change is due now. When it reaches 0%, the system will show that an oil change is past due by an indicated mileage. Along with these reminders, the system will also display either a Maintenance Main Item A or B along with Maintenance Sub-Items 1 through 6 as required.
Factory Recommended Maintenance
Maintenance Main Symbols
Main Item A
Replace engine oil.*
Main Item B/B1
Replace engine oil* and filter.
Service front and rear brakes.
Rotate tires,** inspect for wear and adjust pressure.
Inspect parking brake adjustments.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS)
Check all fluid levels, condition of fluids and check for leaks.
Inspect exhaust system.
Inspect fuel lines and connections.
Maintenance Sub-Symbols
Sub-Item 1
Sub-Item 2
Replace air cleaner element.
Replace dust and pollen filter.
Inspect and adjust drive belt.
Sub-Item 3
Replace transmission fluid.
Replace transfer case fluid (if equipped).
Sub-Item 4
Replace spark plugs.
Replace timing belt, inspect water pump (V6).
Inspect valve clearance.
Sub-Item 5
Replace engine coolant.
Sub-Item 6
Replace rear differential fluid.
Notes:
*Use only Genuine motor oil with a viscosity specific to your vehicle.
**Tires may require more frequent rotation depending on driving conditions, alignment and driving habits.
Specific Additional Required Maintenance
In addition to the maintenance messages shown in the display, having additional services performed at the distance recommended is vital to keeping your RDX in optimum operating condition.
12,000 km Replace rear differential fluid and every 24,000 km thereafter if vehicle is regularly driven in mountainous areas at very low speeds, or if vehicle is frequently used to tow a trailer (4WD vehicles).
Every 24,000 km Replace air cleaner element if vehicle is regularly driven in dusty conditions.
Every 24,000 km Replace dust and pollen filter if vehicle is regularly driven in urban areas with high concentrations of emissions from industry and diesel-powered vehicles.
100,000 km Replace automatic transmission fluid and every 48,000 km thereafter if vehicle is regularly driven in mountainous areas at very low speeds, or if vehicle is frequently used to tow a trailer.
100,000 km Replace timing belt if vehicle is regularly driven in very low temperatures (under -29°C; -20°F, V6 only).
Every 256,000 km Inspect idle speed.
Every 3 years Replace brake fluid.
Old Nov 27, 2006 | 01:27 PM
snorton48's Avatar
I couldn't find an oil change interval in the manual. I think the car tells you on the MID.
Old Nov 27, 2006 | 05:00 PM
Madison3's Avatar
That's how I read it too. My RDX is now past normal the normal oil change period of my previous car (3750 miles) yet my RDX is showing the Oil Life remaining as 40%. It's nice to be able to drive another two or three months without having to do an oil change.
Old Nov 27, 2006 | 07:10 PM
c_hunter's Avatar
What was your previous car? 3750 is a fairly severe interval. Most vehicles have a 7500 mile oil change interval nowadays, or longer (our TSX is 10,000 miles, with a filter done every other time).
Old Nov 27, 2006 | 09:47 PM
Madison3's Avatar
A six-year old CRV that I drove hard...
Old Nov 30, 2006 | 05:46 PM
oblio98's Avatar
WayTooManyAcuras
My info deal just came on, at 5600+ miles! The display shows 15% oil life remaining. It lasted a lot longer than I thought!
Old Nov 30, 2006 | 06:15 PM
Fishbulb's Avatar
The only real way to show the need for an oil change is to do an oil analysis at the maintenance minder interval. I'll probably do this and report back in.
I wouldn't be at all suprised if the oil was still perfectly good by 12k kilometers. The new synthetics are truly amazing.
Old Nov 30, 2006 | 07:00 PM
newteez's Avatar
I think one thing that has happened is the places like Jiffy Lube , Valvoline, etc. Poppd up and came up with a recommended oil life of 3000 - 3500 miles. Almost eveey car manual I have seen says 7500 as the standard interval. Like mentioned syntetic should be longer still, but with the extra heat , combuistion from a turbocharged engine I am going to follow what he car says.
I used to get all my cars done at the 3000k interval and almost all of them had engine problems at the 80K mark so go figure.
JD
Old Nov 30, 2006 | 08:14 PM
c_hunter's Avatar
I agree that the quickie-lube industry has helped perpetuate this myth, and a lot of people buy into it, unfortunately. It wastes time and money, and is bad for the environment. Personally, I stick to the 7500 mile interval in my Subaru. Our TSX has a 10000 mile interval, with the filter changed every other time.
Many people think they need the severe schedule because they encounter some of the severe conditions (hot weather, stop and go, etc), but Honda owner's manuals have always said that ocassional severe driving still falls under the normal schedule.
Old Dec 1, 2006 | 02:57 PM
oblio98's Avatar
WayTooManyAcuras
To reply to my own post, I called my dealer and he said "FORGET IT!!"
He said "Stop by and we'll clear the warning, then schedule an appointment when you get to 7500 miles".
Cool!
Old Dec 1, 2006 | 03:22 PM
acurardx's Avatar
Oil change
Cool!
Mine might not even last till 7500 KMs. It was at 40% when it reached 4000 km
Old Dec 1, 2006 | 04:18 PM
sasair's Avatar
Cool!
I don't know about that... especially on a new model that the dealer has no experience with. It may very well be true, but the dealer has no historical experience with this vehicle or any turbo for that matter. Plus the first oil change is the most important one. If it were a lease maybe....
Old Dec 1, 2006 | 06:14 PM
Madison3's Avatar
And I would think it would still be OK to drive down to 5% Oil Life Remaining. The 15% is the first reminder. The actual "SERVICE" message comes on at 5% (page 331 of the Service Manual).
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
thegipper
Sep 28, 2015 01:01 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
