Different window motor problem....
Greetings all. I just bought a 2007 RDX for my son and trying to get it ready to pass inspection. One of the things that we had an issue with was the drivers side window going up and down slowly and sometimes not moving at all. We figured to replace the window motor/regulator assembly.
Putting in the new one and plugging it in, it only moves about a millimeter and stops. In either direction. So it is getting signal, but doesn't continue. Not only is this strange, but now the front passenger window is doing the exact same thing, where it was fine previously. The rear windows operate as expected, so it isn't the child lock switch.
I have read the procedures in this forum for resetting the given window, and attempted that, but in first or second position, the window (and now fr. pass. window too) still only moves a couple millimeters and stops. They do not continue. Before I replace the switch pack or the door harness, has anyone seen this problem before? Thanks in advance!
Have you lubed the window track?
Yea, unfortunately, I am past that. With the motor/regulator on the bench, both old and new, applying 12v to the primary motor wires, it runs up and down fine. When I plug either in to the car and try to operate the switch, is when it only moves afew millimeters in either direction. I am starting to think the switch pack and its internal controller is the culprit. I want to test everything before I spend $70 on a used one from ebay.
UPDATE: it was the $8 window relay, located near the fuses! Bench testing, the old relay worked fine, had continuity, but must have had high resistance internally. All windows work fine, as expected! And is the cheapest solution, after lubing the window tracks
DaIll1 (08-07-2023)
Nice to see you got it fixed without paying through the nose . At least with a new regulator your son shouldn’t have the glass rattle while partially opened .
My son bought a 2008 RDX two years ago in a snowstorm and loves the ride and power to this day !
FYI .. checkout the radiator/ transmission cooler lines for corrosion if you haven’t. A real time bomb for sure.
JarretF (08-06-2023)
kl323
1G RDX Problems & Fixes
02-14-2011 07:27 PM
frescagod
1G TSX Problems & Fixes
05-27-2006 02:56 PM
