Car shakes at 30mph
Old Mar 18, 2015 | 10:31 PM
08rdx's Avatar
Car shakes at 30mph
I have a 2008 rdx when I accelerate from a stop, the car shakes when it hits 30 mph but after the 30 mph it runs fine. I already changed all 4 new tires and alignment is done. I dont know what the cause is. It only shake when I hit 30 mph then stop and it runs smooth. If anyone has any idea can you please let me know. My mechanic was saying it could be a motor mount thats causing since it only shake at a certain speed. Thanks
Old Mar 18, 2015 | 10:59 PM
UA6's Avatar
UA6
Quite possible the motor mount. What brand tires are you running? I had a similar issue with Nexen tires. Switched to Toyos and the problem went away. Maybe also try getting them balanced at a different shop.
Old Mar 18, 2015 | 11:13 PM
08rdx's Avatar
IAM RUNNING THE GOODYEAR Eagle rs-a2 245/45/19
Old Mar 19, 2015 | 09:48 AM
Jdrum1's Avatar
Am I correct that in interpreting that the shaking started before the new tires?
did it seem to have any impact at all regarding the shaking?
I ask because I've had new tires shake due to improper balancing.
If not that, they another vote for motor mounts.
Old Mar 19, 2015 | 12:35 PM
08rdx's Avatar
The shaking happen about 3 month ago before i even got the new tires. i thought it was my tires at first, thats why i bought new tires. I think iam just going to take my car to the mechanic and have him figure out whats wrong. The shaking is driving me nuts.
Old Mar 19, 2015 | 12:41 PM
Jdrum1's Avatar
Originally Posted by 08rdx
The shaking happen about 3 month ago before i even got the new tires. i thought it was my tires at first, that's why i bought new tires. I think I am just going to take my car to the mechanic and have him figure out whats wrong. The shaking is driving me nuts.
Did the shaking change in any way after the new tires? Not trying to appear hung up on that one thing, but I just suggest 100% ruling out the easiest thing first.
That said, I'd still bet on engine mounts.
Old Mar 19, 2015 | 04:56 PM
GSJake's Avatar
Those are great tires. What about a faulty steering rack, have you checked the PS fluid? Just a thought..
Old Mar 20, 2015 | 01:45 PM
Tomtwtwtw's Avatar
Didn't a lot of people with shaking issues like this eventually have to replace one of the CV shafts up front? Can't find the thread at the moment but I think it's in the problems section.
Old Apr 27, 2015 | 08:56 PM
nator's Avatar
One other relatively easy thing to check is over-tightened lug nuts. The torque setting is a relatively low 80 ft-lbs on the RDX. (Low compared to a "regular" 'merican vehicle)
My wife got a flat fixed once without my knowledge. I noticed a vibration, so decided to pull a wheel. The lug nuts must have had like 200 ft-lbs on them from some numbskull with an overzealous air gun......vibration fixed after loosening and re-torque.....
Old May 9, 2015 | 11:43 AM
08rdx's Avatar
Just had both front axle replace and now car is running perfect. I had a bent axle. So that problem is solved now.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
Legend2TL
Motorsports News
Jan 31, 2016 09:27 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
