Battery Disconnect, Readiness Codes and State Inspection
Old 03-10-2011, 09:31 AM
haole kama'a-ina
737 Jock's Avatar
Emissions readiness codes are proof that your emissons system is functioning. Disconnecting your battery clears all emissions readiness codes that are needed to pass state inspection.
After a battery disconnect you can tell if readiness codes are set by the MIL. Turn the key to ignition II but don't start the engine. The MIL will come on for 15 or 20 seconds. If it then goes off the readiness codes are set. If the MIL flashes 5 times, some of the readiness codes are not set.
The engine will need to be started and stopped several times and the engine will need to reach operating temp in stop and go traffic for 5 to 10 miles to set enough emission readiness codes to pass. Then recheck the MIL before taking it in.
Old 05-08-2011, 11:29 PM
aspectl253's Avatar
what if it still don't set when more than 400 miles driven in stop and go traffic and lots of freeway??? having hte car checked by dealer tommorrow....
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
BigJilm
09-21-2015 08:32 PM
scionxb3003
09-14-2015 01:52 AM
Big mo
4G TL Problems & Fixes
09-12-2015 07:22 AM
Quick Reply: Battery Disconnect, Readiness Codes and State Inspection
