Falken: the experiment.
Old 08-09-2009, 01:13 PM
Anhedonia's Avatar
A couple years ago, Falken decided to branch out and make more then just tires. they contacted Eibach and asked them to engineer some suspension parts for them. A week or so ago, i came across some Falken lowering springs that are NIB going for wholesale. upon inquiring why they were so cheap (72$ shipped) i was told that falked stopped producing them after just a year and a half of production because there was no big demand for them. I also found out they never gained much popularity through not so great advertising and after reading a couple of reviews.. i decided to pull the trigger.
Like i said, they were engineered by eibach and are progressive rate springs. the drop is 1.8 front, 1.7 rear and are available for a bunch of different makes and models, although nothing really past 03-04 (that ive found)
the reason im posting this here and not in the CL section is because of that.. if these springs are in good shape, it might make a nice drop very affordable for more then just CL owners. i ordered them two nights ago, should be in on wednesday and installed by the end of next week. ill keep yall posted
and a before shot just for future comparison..
Old 08-09-2009, 03:57 PM
tmnhs81's Avatar
Link?
Old 08-10-2009, 09:01 AM
boost owns
Audioserf's Avatar
I really had no idea Falken ever made performance parts. They must not have done a very good job of marketing... or I just missed the boat.
Old 08-12-2009, 04:46 PM
Anhedonia's Avatar
they didnt do a very good job of marketing.. i cant find a link for anything aside from info on other forums.
there cold wound springs, shot peened and powdered coated bright blue. each individually serial numbered and supposedly lighter then most other springs while still retaining the same strength.
4 Falken Factory Tuned Lowering springs. Falken, yes the tire company, got into the sport compact tuner market some years ago after the Fast an Furious phenomenon. They made a truly high quality product, but honestly they did not know how to market it. Falken got out of the acceccssory business and sold all their inventory at pennies on the dollar.
Old 08-12-2009, 07:10 PM
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
What are their spring rates compared to Eibach, H&R etc? I'm not a fan of progressive rate springs either but I guess if you get can them for a killer deal...
Old 08-12-2009, 08:10 PM
Anhedonia's Avatar
not sure the exact specs, only that they were designed and made by eibach, then purchased by falken..
whats wrong with progressive rate springs?
Old 08-12-2009, 08:22 PM
Moderator Alumnus
FiftyFive's Avatar
Just be careful, you get what you pay for.
Old 08-12-2009, 08:29 PM
Anhedonia's Avatar
Why would you move this to the CL section? I posted it in car talk for a reason..
and your right, you do; but 70$ is 70$.
Old 08-12-2009, 08:31 PM
Moderator Alumnus
FiftyFive's Avatar
I moved it to its correct forum for another reason. You are talking about putting suspension on a CL. I think people in this forum would be more interested in your findings.
Old 08-13-2009, 05:59 AM
Costco's Avatar
Progressive rate springs are a compromise in order to give you better ride quality while just driving around normally, and still have a high spring rate in order to give you better roll control. Usually the bottom part of the spring has the coils wound far apart to allow more compression during suspension travel, which results in better ride comfort. Then a bit higher the coils become wound tighter to give you that extra spring rate when your suspension compresses enough so you don't bottom out.
I'm just not a fan of progressives. It causes the car to not feel as balanced in transitions. Just think about it.... you're turning hard and at the beginning of the corner the car leans into it and then all of a sudden it tightens up, and depending on how hard you're cornering or road irregularities it can flip/flop between feeling planted and feeling loose even in steady-state cornering (no changes in speed/steering angle throughout a turn). Its just not confidence-inspiring.
spring rate is important because depending on how low you're going, the spring rate needs to be increased in order to compensate. This is one of the big reasons why you don't cut coils on springs, because you're decreasing the spring's travel without increasing spring rate to compensate. Too little spring rate for a drop means your car feels "squishy" over bumps and while cornering, too much spring rate and the car gets skittish and difficult to control, not to mention back-breaking during street driving. There's a fine balance.
Hell.... you might not even notice the difference If it works for you, then great. Honestly, for $70 its worth a try. It may not bother someone who drives calmly on the street most of the time.
Old 08-13-2009, 08:51 PM
Anhedonia's Avatar
i know what they are, and i understand what your saying.. i just think they suit the driving style i employ the best. im not hard tracking the car, and im not going drifting so a soft smooth ride and performance when i need it is ideal.
i wouldnt go with a normally wound spring either though.. if i was going to get anything other then progressive id go with step linear.
Old 08-13-2009, 08:53 PM
Anhedonia's Avatar
your right, but if you read the OP, youd see i posted it in car talk because if these springs DO turn out to be a good deal and ride well, it will be benificiary to all different makes and models. nobody knows that falken made springs.. did you? would you like me to post a new thread after this is done in car talk saying hey everybody look what falken did?
Old 08-13-2009, 09:13 PM
Moderator Alumnus
FiftyFive's Avatar
If it is regarding how the springs performed on your CL then no, keep it in this forum. Thanks.
Old 08-13-2009, 10:50 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,425 Likes on 3,031 Posts
yep doesn't belong in CT
Old 08-13-2009, 11:49 PM
Anhedonia's Avatar
fair enough. then updates when i install them.
Old 08-15-2009, 12:57 AM
Anhedonia's Avatar
oh and i know i posted in the quick question thread about the s-techs. i went to look at them, they were beat to hell, covered in what looked like baked in brake dust and it looks like he had cut them
Old 08-15-2009, 01:27 AM
(Mid-Atlantic)
Old 08-16-2009, 08:16 PM
Anhedonia's Avatar
soooo got off of work around 130 today, headed down to my buddies house by 230 and we started wrenchin. the front came off pretty smooth, none of the bolts were stuck, rubber was all in good condition. it took us two hours max to pull it and put it back together.
we took a break cus it was fucking hot out! then back to work on the rears. the rears were definitely not as much fun. bolts on the bottom of the struts WOULD NOT BUDGE. not with an air gun, 2 days of pb blaster and some good ol fashion elbow grease. sooo we dropped the sway, compressed the spring and wiggled it out while leaving the strut still connected at the base.
The ride is so tight. it handles 10000x better. its pretty damn stiff, but soft enough not to feel every single little bump. its flush, no tire tucking. perfect IMO. i love the ride, it feels great. overall very satisifed, id definetly reccomend these to anyone.
All in all, it was good hard work. went smoothly minus the one speed bump and everything fit together perfectly. i only took two pictures tonight as im waiting for it to settle for a couple of days. come wednesday or so, ill shine her up and snap some good pictures.
stock spring comparison.. stock is on right, falken's on left
noowwwww
Before:
and after:
sorry for shitty pictures, it was getting dark out and it took me about 8 tries to get a snap without blur. again, better pictures soon.
Old 08-16-2009, 08:17 PM
Anhedonia's Avatar
come to think of it.. it actually doesnt look that different in those pictures LOL
ill have to snap some more tomorrow.
Old 08-16-2009, 08:42 PM
Custom User Title
Gnate's Avatar
looks good.
Old 08-16-2009, 10:03 PM
(Mid-Atlantic)
looks good man congrats
Old 08-16-2009, 10:06 PM
Anhedonia's Avatar
^^ yeah finally thanks haha. although no more 4 wheeling for me
Old 08-16-2009, 10:07 PM
Anhedonia's Avatar
and now that im dropped, im noticing more and more shit about my wheels, like how theyre not as flush as i once thought. anyone know what size spacer will get the stockies out flush? or will i just have to experiment
Old 08-16-2009, 10:11 PM
Custom User Title
Gnate's Avatar
they sell spacers on ebay that are pretty decent according to fliplyricist.
Old 08-16-2009, 10:17 PM
incredulous1's Avatar
if your gunna change wheels, id say you should save your cash and buy some wheels with the correct offset to get flush. it would be more reliable than spacers IMO
Old 08-16-2009, 11:29 PM
Custom User Title
Gnate's Avatar
I wouldnt mind haveing something like cocoas. But i'd feel bad getting the same shit and spending that much money
Old 08-17-2009, 01:43 PM
Anhedonia's Avatar
moar pictures now that its light out
sorry my fatass finger got in the way of that one
now its time for some wheels
Old 08-17-2009, 02:07 PM
(Mid-Atlantic)
deccent drop, a little conservative but like u said hopefully it will settle a bit more, I know my teins did. Rims def shoul dbe next on the list
Way to use the mudguard as the lowest point for the pic
Old 08-17-2009, 06:36 PM
Anhedonia's Avatar
its 2.2 lower then it was, now. and im hoping for at least another quarter inch out of them.
its nice because i dont have to worry about every single thing in the road, although i did scrape my rear bumper today
Old 08-17-2009, 06:47 PM
i like acura
spencer_homer's Avatar
whats with the overspray?
Old 08-17-2009, 10:23 PM
Anhedonia's Avatar
that wheels been a work in progress. it was severly curbed and rashed when i got it. ive been slowly filling and repairing it when i get a chance, this has been going on for a month.. two times ago when i taped and masked it off, the tape didnt adhere well to the rubber and the paint leaked under it its slowly coming off, but it just takes time.
Old 08-18-2009, 12:14 AM
Custom User Title
Gnate's Avatar
c00lio!
Old 08-18-2009, 12:47 AM
(Mid-Atlantic)
I hear ya man, I scraped yesterday like 3 times and smashed a pothole today, I raised the front a half inch too cuz I was scrapin too much and didn't even put my lips on yet.
Old 08-18-2009, 01:02 AM
Anhedonia's Avatar
gah, i want to go lower, but i know ill kick myself for the quality of the roads here.. ill take a picture of the driveway at work i have to get up everyday
some fresh scratches on the bottom side of my rear bumper coming down it leaving work lol i need to find a new spot to park.. thank god my driveways ok!
i see the benefit of coilovers now more then ever.. one day, ill upgrade.
Old 08-18-2009, 01:17 AM
Death to Fresh
mcajka's Avatar
i scrape / grind /rub / bend my bumpers daily. i love the look on peoples faces though when they hear it and see me getting out of places. looks good though im impressed with the drop
thisaznboi88
07-04-2015 01:51 PM
georgelv1999
11-24-2014 12:08 PM
JimiThng
19
11-03-2007 08:15 AM
aznfunkyflip
02-15-2007 09:11 AM
Quick Reply: Falken: the experiment.
