Eibach Prokit Drop?
Eibach Prokit Drop?
Well, my friend told me that Eibach Prokit springs would give my 1stgen CL a greater drop because my car is heavier... can anyone confirm this? and if so... how great is the new drop then? thanks
Uhhh, greater drop compared to what? Stock, if youre comparing it to stock then definately it is lower. But generally Prokit doenst have as much of a drop compared to Eibachs sportlines, H&R sports, etc...
I wouldn't even bother with the pro-kit. I made the mistake of getting the pro-kits because the thought of not getting new shocks and no camber wear attracted me. BIG MISTAKE! I got the Tein's and I loved them.
Originally Posted by shineynitelite
the eibach pro kit would be perfect for me because i have to worry about snow and stuff like that, if you live in hawaii the teins are without a doubt the way to go
If your gonna get PROkits......like I do.
Its a good idea to also get shocks.....because if you install the ProKITs...with your stock shocks.
Then the drop is gonna dissapoint you.........with aftermarket shocks......it will lower the car more. So if you get eibach PROkits......def. change your shocks too.
With KYB AGX shocks.......or any other quality company.
Suspension Q
Do You Need a Chamber Kit WIth Pro-Kit Drop? It Claims 1.3 correct?
How about the H&R Drop Do you need a Chamber With that Claims 1.5?
Do You Guys Reccomend KYB's Or TOkIcO's? With those Spring/Shock Set up ?
Ohhh Yeah... Also Guys Which drop would you guy suggest if i have a WW LIP and i need to be able to make it up drive ways with out scratchin the WW LIP... I PLAN to drop my car after my warrenty is up at 60k.... Im at 45 k =)
Listen, if you're gonna get springs AND shocks, why not just shell out another couple hundred bucks (at most) and get a full coilover setup that your friends (and most people here) would love you have.
*I recommend Koni Yellows or KYB AGX's.
Originally Posted by dennis
No, you don't need camber kits with a pro-kit drop. Anything 1.7" or more, you need camber kits.
hello.. mr lazy here
Originally Posted by CL Platano
I know I don't wanna be messing with dropping it and raising it depending on the weather and road conditions. When its 0 degrees outside who wants to be messing with their suspension setup.
That's why you do that before the bad weather...
Don't you guys know how to plan?
It's easy and fast to raise or lower a car. I used to do it all the time. My suspension changed weekly with my mood.
Originally Posted by satinsilvercl
So Prokit w/ KYB's...I should be straight rite? Any treadwear I should worry about?...compared to the ideal set up--tein
Pro kit and KYB's should be fine. It will not increase your tread wear because its not that dramatic of a drop. You should be good.
emailnatec
29
09-28-2018 04:27 PM
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
us285126
10-02-2015 02:03 PM
4drviper
09-23-2015 07:42 PM
