Adr?
Old Apr 24, 2007 | 07:01 PM
CLpwner's Avatar
Mmmm...
Adr?
Sorry to start a new thread... I'm sure this brand has been discussed before... But you can't search for ADR because its too short... so ne way
Has ne one had experience with ADR wheels? For example:
Old Apr 24, 2007 | 07:14 PM
hornedfrog2000's Avatar
B A N N E D
You and I will probably get flamed for this, but I actually have them and I am pretty happy so far. I would like something nicer, but I don't have a ton of money for it. The only thing I am worried about is having them get bent from potholes or something. If I could buy rims again I would get the axis mod sevens...noice.
Old Apr 24, 2007 | 07:21 PM
CLpwner's Avatar
Mmmm...
yea... thats why I'm thinkin about going with them... I have probably the least amount of money possible to still be able to work on my car sorta... I mean they look good... better than stock... and do they seem like they are gonna get bent from potholes? that unsturdly built?
Old Apr 24, 2007 | 07:33 PM
B A N N E D
They seem fine to me, but I know they were cheap, and I just pay more attention to the holes. I look at my rims every once in a while, and they don't look dented or anything.
Old Apr 24, 2007 | 07:36 PM
CLpwner's Avatar
Mmmm...
sweet... thanks
Old Apr 24, 2007 | 08:11 PM
B A N N E D
Originally Posted by CLpwner
sweet... thanks
I think your swell too.
Old Apr 24, 2007 | 08:23 PM
CLpwner's Avatar
Mmmm...
hahahahaha that just made my day well night...
Old Apr 24, 2007 | 09:08 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Several people have had ADR's on here, but they're not super popular because they are cheap and generic, those rims you posted above are phat though
Old Apr 24, 2007 | 09:40 PM
aznboi2424's Avatar
i have ADR's and they are pretty good for me. just gotta be more aware of the potholes but that is prob with all rims since you are gonna have thinner rubber.
Old Apr 24, 2007 | 11:10 PM
klepto's Avatar
adr is one of the better "knockoff" wheel companies
Old Apr 25, 2007 | 09:14 AM
saiko_cl_duck's Avatar
be careful, they do bend easy.
Old Apr 25, 2007 | 09:29 AM
(Mid-Atlantic)
They do bend easy though, but so do most all aluminum wheels
Old Apr 25, 2007 | 05:25 PM
CLpwner's Avatar
Mmmm...
Cool... So what that makes them on a scale of 1-10 a 6ish?
I only choose the best... haha except the blue strut bar...
damn... oh well?
Old Apr 25, 2007 | 07:23 PM
CLpwner's Avatar
Mmmm...
205/40/17 - 23.5" diameter (35-45mm offset required)
205/45/17 - 24.3" diameter (38-45mm offset required)
205/50/17 - 25.1" diameter (38-45mm offset required)
215/40/17 - 23.8" diameter (38-45mm offset required)
215/45/17 - 24.6" diameter (40-45mm offset required)
225/40/17 - 24.1" diameter (42-45mm offset required)
225/45/17 - 25" diameter (42-45mm offset required)
Being as that I'm super i have no idea what all that means... well sorta but why are there so many options...
the ones pictured above are:
SIZE: 17 X 7
40 OFF SET 8 HOLES UNIVERSAL 4X100/4X114.3
the link to them is:
ADR RIMS BIA!
I don't know about the 215/40 thing about them... what is that ne way?
And I wanna get tires so that the speedometer is not messed with...
thanks
Old Apr 25, 2007 | 07:28 PM
B A N N E D
The speedo shouldn't be off by much at all really, and I would go 18s if I were you. 225,40,18s...or 215. The price of tires from 18-17 isn't that much different.
Old Apr 25, 2007 | 07:54 PM
alright, here goes.
205/55R16, which is a stock CL tire
Let me break it down.
205- width of your tire. This would be how wide your tire is from side to side
55- height of the sidewall. Take the distance between where the rim meets the tire, and go to the outside edge of the tire.
R- Radius, math class FTW!
16- Size of the rim, in inches.
Old Apr 25, 2007 | 08:14 PM
CLpwner's Avatar
Mmmm...
alright, here goes.
i see... this is measured in millimeters im speculating? and so... If i went 17's then i would want like... 35 sidewall? so that it is approxiamtly the same?
why 18? I mean... the rim would cost more right? I think so... also... I kinda like 17's... ZeroCL... if you check this out, what size do you have... in ur avatar?
Old Apr 25, 2007 | 09:48 PM
B A N N E D
I just think 18 with 40s look about the best. The price might end up being a tiny bit more, but I think worth it.
Old Apr 26, 2007 | 12:57 AM
aznboi2424's Avatar
i have 40/18s but i forgot if they were 215 or 225
Old Apr 26, 2007 | 01:36 PM
woah man, 35's on a 17 would be real bad, plus you'd be way off on the speedo.
Think 45's, that's a nice fit on 17's, maybe 50's if you like more sidewall, but 45 should do.
for 18's, think 40 series rubber, no bigger. But don't go rollin on 35's unless you want bent rims like subbuzz.
If you're looking for a good size on 17's, go with a 215/45, that'll look real nice without worrying about rubbing at all.
Old Apr 26, 2007 | 02:23 PM
B A N N E D
17x35 would look horrible. unless it was slammed totally to the ground, and even then it wouldn't look right. If I did 17s I would put at least 45s on there.
Old Apr 26, 2007 | 07:39 PM
CLpwner's Avatar
Mmmm...
oops... i read that wrong i saw it as 45... so then i took some off that to get 35... i meant to say 45 or 40ish cuz 55 is way too gigantic ... but i also dont want as slim as the ronjon ad at the top right...
Old Apr 27, 2007 | 05:07 PM
CLpwner's Avatar
Mmmm...
In that thread with the batmobile guy... are those 40's? or less or more?
Old Apr 27, 2007 | 05:33 PM
B A N N E D
If his rims are 18s, I would say yes they are 40s.
Old Apr 27, 2007 | 05:36 PM
RYANGP's Avatar
Not a doctor
ADR = Another Dented Rim
but i say just take it easy and be careful and you should be alright
Old Apr 28, 2007 | 04:04 PM
CLpwner's Avatar
Mmmm...
FFFFFFFFFFF... I cant find them on eBay ne more...
me
Old Apr 28, 2007 | 05:48 PM
CLpwner's Avatar
Mmmm...
18" ADR's check it...
how bout those?
Old Apr 28, 2007 | 06:35 PM
B A N N E D
Daddy like. If I could do it again I would go with something more like that.
Old Apr 28, 2007 | 08:53 PM
CLpwner's Avatar
Mmmm...
haha... yea... so with this I would want 40 tire right? I'm trying...
Old Apr 28, 2007 | 08:56 PM
B A N N E D
Thats what I would get man, and thats what I have. If you go 35 they don't look right, they make the rims look smaller, and make your wheel well gap look bigger.
Old Apr 28, 2007 | 09:05 PM
CLpwner's Avatar
Mmmm...
so it would be 40 not 45 or something... oh and i only said 35 cuz i have no freaking clue what I'm talkin about with rims/wheels...
Old Apr 29, 2007 | 08:46 AM
CLpwner's Avatar
Mmmm...
oh and with these... how much would the speedo and odo ( ) be off?
Old Apr 29, 2007 | 10:43 AM
B A N N E D
It wouldn't be off by much. I know there are formulas around here to figure it out though if you really want.
Old Apr 29, 2007 | 04:48 PM
CLpwner's Avatar
Mmmm...
just bought those...
now the tires... they should be 40 or 45... !! haha
so excited
Old Apr 29, 2007 | 07:43 PM
CLpwner's Avatar
Mmmm...
By the way HornedFrog... wtf is ur avatar.......?
Old Apr 30, 2007 | 11:05 AM
B A N N E D
Its a picture of me at my graduation.
Old Apr 30, 2007 | 11:12 AM
40 series tires bro, don't go 45, and don't go 35. Your speedo should stay relatively the same.
Old Apr 30, 2007 | 03:09 PM
B A N N E D
Just kidding, its that dude from the movie mask. The one with Cher. Ugly as hell huh.
Old Apr 30, 2007 | 08:43 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
Use this tool to see how the tire sizes affect your speedometer: http://www.miata.net/garage/tirecalc.html
The stock size is 205/55/R16.
Old Apr 30, 2007 | 08:59 PM
B A N N E D
Nice tool sleeper. So, with my setup the calculator says I will be going 60.5 mph when my speedometer says I'm at 60mph . So don't even worry about it. That is 225/40/18s
