Wipers????
Old Jan 16, 2011 | 04:16 PM
JDM97CL's Avatar
Wipers????
Well about a week ago my wipers stopped working. Well i just checked to see if the motor worked. and it does becasue each level it goes faster and faster. Well im wondering why wont the wipers move? can anyone help. thanks
Old Jan 17, 2011 | 06:34 PM
97'CL2.2's Avatar
ur nylon connectors probably came unsnapped. do i search for "play in wiper mechanism" you will find all the info u need....good luck
Old Jan 17, 2011 | 07:41 PM
JDM97CL's Avatar
Wordddd Thanks
Old Jan 17, 2011 | 08:51 PM
rush's Avatar
03 acura cl type s
mines opposite once i turn it on i have to turn the ign off before it goes off
Old Jan 18, 2011 | 12:50 PM
JDM97CL's Avatar
This is what fell on ny car. I just figured it out. Now does anyone know what i need to do to put it back on?
Old Jan 18, 2011 | 04:10 PM
97'CL2.2's Avatar
ok so u removed that?..is that what your going for?...and found something disconnected?...im a little lost with what you are asking..if all u want to kno is how to put it back in just reverse what you did to remove it...its tricky tho...sometimes easiest to remove the brace holding the two ends together(the part which bolts on both ends) and install the assembly then bolt that brace on
Old Jan 18, 2011 | 05:15 PM
purple3.0haze's Avatar
i had this happen to me, don't open the hood with the wipers up!!
Old Jan 18, 2011 | 08:12 PM
JDM97CL's Avatar
@ 97'Cl- no i found this picture on another thread. But what is circled in red is what is diconnected on my car. The whole wiper system is still in my car. But im wondering how to reconnect that rod that is circled in red.
Old Jan 20, 2011 | 12:40 PM
P0401's Avatar
not sure how to reconnect that rod, if its some type of rivet you can drill it out and put a bolt and nut on it, that is if you can get to it. if you can't get to it you may have to remove the mechanism to drill it out and bolt it up. I have no experience in this so I am just throwing out suggestions
Old Jan 20, 2011 | 04:06 PM
JDM97CL's Avatar
Im going to take it out now to see what i can do hopefully i come out of this with it fixed.
csmeance
Jan 7, 2026 06:25 PM
TL-Rocket
Apr 29, 2023 02:33 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
wb2ee
2G RDX Problems & Fixes
Sep 22, 2015 12:00 AM
iRaw
ILX
Sep 18, 2015 12:44 PM
