Window problem
Old Jun 6, 2008 | 05:32 PM
Gunshock's Avatar
Window problem
Hey on the passenger window, the passenger cannot roll their window up. They can roll it DOWN, but not UP, so I have to roll it up for them.
Whats wrong with it? Just the button?
Old Jun 6, 2008 | 09:37 PM
tron's Avatar
prolly the switch or wiring. You could determine which is the culprit with a voltmeter or multimeter. Test for current before and after the switch.
Old Jun 6, 2008 | 10:56 PM
CLpwner's Avatar
Mmmm...
Weird... I have the same problem, its never bothered me enough to fix it though, because I'm at no loss from it... :-)
Old Jun 7, 2008 | 08:43 PM
Gunshock's Avatar
thanks I will try the voltmeter or multimeter if I can. Ill post results whenever I get to it.
Old Jun 14, 2008 | 08:00 PM
TexasHonda's Avatar
Dirty or broken window door switch. I've managed to repair some switches by removing, disassembly, clean and reassemble. Small parts so kinda tricky.
Hardest part is door panel removal w/o damaging door panel.
good luck
Old Aug 5, 2009 | 06:32 PM
Gunshock's Avatar
oh i finally fixed it and yes it was the switch. I just ordered a passenger window switch from ebay and it worked. Thanks!
Old Aug 10, 2009 | 02:47 PM
nappykhaki's Avatar
Thumbs up darn motors
Hey gotta get a new motor, you cant roll an ac with busted windows go to the pay and pull junk yard and pull you a good motor
SidhuSaaB
May 30, 2020 12:40 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
wcimo
Sep 21, 2015 10:55 AM
ahsm
Sep 9, 2015 08:35 AM
