where is VTEC solenoid....
Old Aug 28, 2009 | 10:37 AM
fromztosuv's Avatar
I'm havint problem with VTEC not kicking in & my oil is full... Does anyone know where is the VTEC solenoid is located & if you have a picture that would be GREAT!
Old Aug 28, 2009 | 02:52 PM
Blazin Si's Avatar
How do you know it's not working? SOHC VTEC on the D and F series is shitty and quiet. You can barely hear it with an intake and makes almost no noticeable difference in the powerband.
Here's the solenoid.
Old Aug 29, 2009 | 07:27 AM
fromztosuv's Avatar
Thanks...
I assume its not working because my car is kicking in and out when I try to accelerate pass 4000rpm.
Also I've had an oil leak from my distributor (2 quarts per full tank) for over a year which I let get too low last month. Since that day I'm getting code P1259 even after i topped of the oil.
In addition, about a month prior to the 4000 rpm issue, I cracked a gray connector located directly below the distributors left side (which screws into the engine block) thats full of oil dripping from the distributor. I just kinda pushed it back into the connector.
All in all The car drives fine. I simply can't pass 4000rpm in any gear since this occurred. I was thinking of cleaning the vtec solenoid filter, or checking the connection to the oil pressure sensor if someone can tell me where the sensor is located...
Any input to help resolve is GREATLY appreciated!
Old Aug 29, 2009 | 02:54 PM
Blazin Si's Avatar
You should still be able to take the engine to redline even without VTEC engaging. Do you have a CEL?
Old Aug 29, 2009 | 04:14 PM
fromztosuv's Avatar
CEL code is p1259.
IBankMouse
Jun 13, 2020 12:53 PM
Dunnik
Sep 15, 2015 11:52 PM
Tsov Tom
Sep 6, 2015 07:56 AM
Desert Ridge
Sep 5, 2015 09:47 AM
LAMike240
Sep 3, 2015 04:35 PM
