Wheel Stud Replacement
Old Mar 13, 2011 | 02:10 PM
cyphon21's Avatar
Hey all,
So I am looking to replace a wheel stud on my right front wheel. The lug was improperly put on and it stripped the stud.
I searched but couldn't find a write up or anything on how to do this. I have never done this before, so any help is appreciated.
Thanks!
Old Mar 15, 2011 | 06:15 PM
cyphon21's Avatar
No one knows? Or is it that easy of a job haha... I looked on HT and it shows a method, but not sure if it's the same for us.
Im assuming we have to take the rotors off right?
Old Apr 3, 2011 | 12:46 PM
65 Fury Convert's Avatar
Is it a '97? If so need to pull the rotor to take of the hub plate that the studs are pressed into.
Old Apr 4, 2011 | 10:30 AM
cyphon21's Avatar
Yeah it's a 97. I figured it was just taking off those things and then just getting a BFH and giving her a nice hit to get it out.
Old Apr 4, 2011 | 04:48 PM
There might be a "window" from behind the rotor you can access removing the stud from. It's going to be a PITA without it off the car though. You'll have to remove the 4 bolts that hold the hub plate to the rotor - if I remember it's a 14mm - use a 6 point socket not a 12 point. I remember taking mine of with a 12 point and 1 bolt out of 4 stripped. The hub plate will now turn independantly of the rotor. Now get behind there and see if you there is a window to push the old stud out of and push the new one into.
Old Apr 4, 2011 | 08:14 PM
timeizmoney22's Avatar
Going to attempt this as well this week. I have 2 that need replacement, but my 97 has 98 knuckles so it should be easier. I can take pics but not too good with the write up stuff.
Old Apr 4, 2011 | 08:33 PM
You have the 98 rotors? Then it'll be easy for you - as in count your lucky stars easy - I had to pull my rotors a month or so back and what a pain in the arse!
Old Apr 4, 2011 | 10:34 PM
Gonna have to deal with that soon as my wifes 95 accord needs new rotors soon and it's the same setup(hub over rotor). That's exactly why I bought 98 knuckles out of a junked 98 cl to avoid any further headaches.
DUECE_DXJ
Sep 24, 2015 04:54 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
cammy5
Sep 4, 2015 11:26 PM
heyitsvic
Sep 4, 2015 09:38 AM
mtl_ilx
Sep 3, 2015 09:48 AM
