Warm Air When A/C Is on
I just had my A/C Refilled and there are no leaks or anything as per the place i got it filled. I recently replaced the A/C condensor so the system needed a refill.
Problem is, it is still blowing warm air even though the a/c system is seemingly working / is filled.
The a/c shop said it was something within the car (not in the engine bay) that is not switching correctly, causing it to still be blowing air from the blower.
Any ideas? I really dont want to pay for exploratory work if it is something i can fix myself..
Try hitting the defrost button, leave it on for about five secs, then hit it again to turn it off. Don't know why, but that worked for me to switch the cold on. Let me know if it works.
Was it a reputable shop, maybe they over filled it, put the AC on full/high watch/listen for the compressor to kick in, if its kicking in and out(clicking on/off), they over filled it..........cant just go by the gauge at a point, there is a fine line between it being 100% fill or overfill..........
ive tried turning ac off and then defrost on
and just switching defrost on/off
no go.. i can definetly feel the blowing change etc but just no cold air
the ac @ the compressor def sounds to be switching over
but i cant really hear anything switching inside the car
its like theres something inside the car that should be routing cold air in that isnt..
im no expert =\
and the ac shop is reputable for sure.. i got a receipt and warranty for the fill and there were lots of cars there at the time getting refills w no probs.
at one point when i was near my car when they were filling it it sounded like the car was on but it was like spooling up and dieing.. no idea wtf was going on there..
im just affraid of paying their $90/hr rate and then have them spend 2+hrs to tell me they couldnt figure it out... tbh i dont think i should have been charged for the fill if it didnt work after the fill.. they said its not leaking and if i need another fill this season its free.. but yeah, it wasnt working even when i picked up the car from them.. ugh
Have someone adjust temperature while you watch the heater valve in the engine bay. Maybe the valve is stuck open on heat mode? They are notorious for rusting. The valve is near the firewall towards the middle-ish, small 1.25" black rubber hose and you will see a skinny, likely rusted, actuator arm going to it.
SidhuSaaB
05-30-2020 12:40 AM
Biggie_B
02-26-2017 11:14 AM
rcs86
08-02-2016 06:52 PM
