Vehicle Speed Sensor
VSS is on back side of engine near the thermostat housing. Pull air instake duct to gain access. There is a tiny drive link between VSS and transmission connection that will sometimes stick to the VSS and drop out if you're not careful.
OBD1 code 17 should be present for a bad VSS.
good luck
good luck
cycdaniel
12-17-2019 10:58 AM
