Timing belt
Old Dec 10, 2005 | 07:08 PM
tanny's Avatar
7th Gear
Timing belt
I am trying to change the timing belt on a 1997 Acura CL 3.0 and am having trouble getting the bolt out that holds the harmonic balancer to the crank. I just want to make sure that the bolt has a normal thread(rotates counter clockwise to remove) and not a reverse thread. Has anyone taken one off? Thanks, Victor.
Old Dec 10, 2005 | 08:17 PM
ayougo's Avatar
B A N N E D
its does, but it requires a CRAZY amount of TQ. You'll need a very healthy air compressor and air tool to get it off or you'll need alot of leverage/breaker bar 4 feet long
Old Dec 11, 2005 | 07:35 AM
tanny's Avatar
7th Gear
I like the Santa getup. So at least I'm pulling the right direction on that bolt. Any ideas on how to keep the crank stopped while I put a breaker bar to it? It's an automatic, so I've just been using an impact gun, which hasn't worked(supposedly a 600 pound max torque gun). Thanks for answering my thread. Victor.
Old Dec 11, 2005 | 10:49 AM
ayougo's Avatar
B A N N E D
your gun might be strong enough, but unless your air compressor supplies it with its recommended psi at a consistant rate, your gun may never see even 300 foot poungs !! have somebody step on the break while in park and take a 4 feet long breaker to it ( just put a pip over it ) and make sure your extension is at least 1/2 inch and thick so your out of the wheel well. THen break it off. The best way to do things, is have a shop take the bolt out for you.
Old Dec 11, 2005 | 11:41 AM
cl3.0dude's Avatar
when i did it on a 4 banger / standard, i had to pull the starter. then i wedged a tire iron in the flywheel and clutch. that locked the engine down. then lift the front end and put it on jack stands, make sure the car is sturdy. i all ways use my E-BRAKE. youll need a 1/2 " break over bar atleast 2 foot long. ONLY USE A BLACK IMPACT SOCKET. WHAT WORKED FOR ME IS I SIT ON THE GROUND AND GRABBED THE BUMPER AERA. I PUT MY FOOT ON THE BREAK OVER BAR, AND PUSHED LIKE HELL WITH MY FOOT. THIS HAS WORKED FOR ME TWICE. ONCE ON A CIVIC 1.5L , THEN ON A INTEGRA 1.8L. THAT BOLT IS PRETTY HARD TO BREAK LOOSE BUT IT CAN BE DONE. GOOD LUCK
Old Dec 11, 2005 | 01:43 PM
ayougo's Avatar
B A N N E D
or just have someone sit on the breaks in 5th gear. Its alot safer and easier that way
Old Dec 11, 2005 | 01:51 PM
penaduny's Avatar
Official AZ photochopper
yea.. did my freinds car used a four foot bar, 2 broken sockets later it came off..
just had my car done.. my freind is the service manager at a dealer, so it was done cheap enough for it not worth doing myself. (paid 360 for parts and labor, TB, waterpump, crank seal, cam bearing seal?, and a few other random things)
Old Dec 12, 2005 | 07:06 AM
tanny's Avatar
7th Gear
MY main problem is the automatic tranny. How can I stop the crank from rotating when I apply force to the crank bolt? Easy to do on a manual shift, but what about an automatic? Thanks.
Old Dec 12, 2005 | 08:07 AM
tanny's Avatar
7th Gear
Ayouga, didn't register that you said to put it in park. Definitely getting senile. Thanks.
Old Dec 18, 2005 | 10:54 PM
krazy99cl's Avatar
O.G.
that bolt is hard man...put that car as far as you can get it and use a long bar....my friends and I held on to the radiator support and bounced on the wrench....dealer was going to charge almost 1000 for labor alone...if your rich then you can do that...try using a leverage bar....
Old Dec 19, 2005 | 10:16 AM
tanny's Avatar
7th Gear
Thanks everyone for the info. I finally had to order the $50 special tool to hold the pulley still while I used a breaker bar clamped to the end of a six foot 2x4. No problem. Lots of bruises and skinned knuckles messing with that 3 inch clearance. Car is back together with a new timing belt, water pump, accessory belt, and power steering belt. Don't want to do this again. Ever.
Old Dec 19, 2005 | 08:47 PM
Pancho's Avatar
The tool you used to hold the pulley - did you have to use a honda/acura part? Or would a standard one that I could loan from Napa do the job?
Old Dec 28, 2005 | 07:21 AM
tanny's Avatar
7th Gear
I never checked to see if Autozone had the correct tool. I should have. I just went ahead and purchased the tool off the internet.
Old Dec 28, 2005 | 07:51 AM
wilp99's Avatar
putting the tranny in park wont stop the engine from moving. automatics dont work that way. and if you would have put the breaker bar on the bolt. turned the crank totally clockwise till the bar was against the frame you could have disconnected the ignition coil and bumped the starter. the 3.0's natural rotation is clockwise so the engine would have broken the torque, sorry i didnt see this thread till today.
Old Jan 3, 2006 | 07:36 AM
tanny's Avatar
7th Gear
Good idea. Would never have thought of it of course. Thanks.
Old Jan 4, 2006 | 12:22 PM
wilp99's Avatar
it only works on a few motors.. the others spin the wrong way.. and if you dont have it on a sturdy spot someone could get hurt.
vaughanml2
Nov 1, 2021 10:16 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
